Raw files only appear as small icons in Bridge. Using CS3. Photoshop is working fine with Raw files. need help to see files in Bridge
Your Bridge cache may be corrupt. Try to purge the cache of the folder in question, or just right-click a raw file and select Purge Cache for Selection, followed by Generate High Quality Thumbnail.
You don't say much in your description. Has this onloy started to happen? Has it been working before? Is this one folder or all folders? More info please.
Here is the message I tried to send. Thank you for your help
It all started with blue screen of Death on my machine. I had to completely reinstall everything. The update function in Bridge tells me there are no updates. So I assumed that Adobe stopped supporting CS3. I went to Adobe website and downloaded the Raw Camera File update. If I double click the raw image it will open in Photoshop just fine but the thumbs in Bridge are small icons with .nef. The functionality used to work in Bridge prior to reinstallation. When I right click a raw file there is no purge cache. however I did purge the cache in tool function. I find the "generate high quality thumbnail" under the edit function, did that. Still does not work. This happens in all folders. Having to open all the photos in photoshop rather then see them in bridge, really slows down the abiltiy to view photos.
Unclear why a "blue screen of death" required a re-installation. Also, did you reset your preferences as this file unaffected by a re-install? Hold down Ctrl and Start Bridge. Should get reset window. Choose all 3 options.
Did you have cache exported to folders option checked? If so you will have to also purge each folder cache manually in Tools/cache/purge -----.
Blue screen of death is frequently a driver issue.
This sounds to me like you installed the updated plug-in incorrectly.
It's a common mistake to pick the wrong plug-in folder when copying Camera Raw. Unlike Photoshop plug-ins, plug-ins which work in Bridge must be installed in the 'Common Files' directory branch. On my computer, Camera Raw (Camera Raw.8bi) can be found here:
C:\Program Files\Common Files\Adobe\Plug-Ins\CSx\File Formats
Similar Photoshop-only plug-ins are located here:
C:\Program Files\Adobe\Adobe Photoshop CSx\Plug-ins\File Formats
Note that they are similar but different, and consequently quite easy to confuse. Also note that you should ONLY HAVE ONE copy of 'Camera Raw.8bi' installed (or two if you're running 64-bit Photoshop). So, if you previously installed the update in the wrong place, you should remove it, and put it in the correct place.
Hope that helps.
