Terminal Server Adobe Acrobat problem updater
Jul 16, 2012 11:08 AM
Right now we have a problem where everyone keeps getting prompted to update adobe. We have a lot of terminal server users. When we turn this off it is on a per user basis not system wide. So I have been looking into the custimaztion wizard and tested out removing this feautre to re-deploy them. Is there still a way we can manually update adobe if we take out the update feature? Or is there other options to do this system wide so users dont keep getting prompted or rebooting the server.
    Jul 16, 2012 12:15 PM   in reply to corptech
    Certainly. Disabling the Updater does not prevent updating whenever you want. Simply run the installer.
    Ben
    Jul 16, 2012 12:59 PM   in reply to corptech
    Yes. The updater preferences only control what appears in the UI and how often a check for updates occurs. Most enterprise admins disable the updater so they can control what version is installed across their organization.
    You should get the Admin Guide and the AIM app so you can learn about the full range of configuration possibilities.
    http://www.adobe.com/go/acrobatitinfo
    Ben
