daveyboyl
Exiting from an event
Jul 16, 2012 5:44 AM
Apologies in advance for what is probably a really basic question however I can't find the answer anywhere...
is there an easy way to exit from an event without executing all the formcalc code?
Cheers,
David
    Jul 16, 2012 10:49 AM   in reply to daveyboyl
    Hi David,
    If you have a look at the end of this example, you will see how you can check how the user has exited the field. Wrap the condition you want in an if statement.
    http://assure.ly/j1KdNq
    Hope that helps,
    Niall
    Jul 16, 2012 11:15 AM   in reply to daveyboyl
    Sorry David,
    I answered thinking I was in a different thread.
    I would approach it from:
    if (check eq passed) then
         // your script block
    endif
    So that the script inside the if statement will only fire if the condition is met.
    Does that make sense?
    Niall
    Jul 16, 2012 12:02 PM   in reply to daveyboyl
    Hi David,
    "return" is reserved for use within a function. You cannot use it outside of a function.
    "break" is used within a loop or switch statement.
    Not sure about "exit", but I suspect not.
    Niall
