Background Images Not Resized When Rescaling Project
Jul 16, 2012 1:23 PM
I'm having a problem with rescaling projects. I noticed that some slides looked very distorted while others looked fine. I realized when I opened the background images in an image editor, that some of them were rescaled to match the new size of the project, but some were still their original size. The ones that were not resized look very bad until I manually resize them.
Has anyone run across this? Is there something I can do to ensure that the background images are resized so that I don't have to do it manually?
    Jul 16, 2012 2:32 PM   in reply to Ashley_Drew
    Never had this problem. Which version of Captivate are you using? And did you downscale or upscale. It is never a good solution for bitmap files...
    Lilybiri
    Jul 17, 2012 12:57 AM   in reply to Ashley_Drew
    Did you check if there was a significant difference between the backgrounds that downscaled fine and the ones that didn't? Some ideas: created from scratch or not, based on a master slide or not, created by a capturing or not? I'm just trying to find a reason because I didn't hear such an issue with 5.5 up till now on the forums,
    Lilybiri
