ddr3500
Can you tell me what tool and settings I used?
Jul 16, 2012 10:02 PM
Tags: #replicate #work
look at the picture, it seems I used a brush to do the red line and inner blue and outter white but I can't replicate the exact thing can you guys tell me what tools I used? The line at the bottom is the one I want to replicate. The line at the top is the one I get from simulating settings.lineas.PNG
  • Noel Carboni
    Dec 23, 2006
    Jul 16, 2012 10:04 PM   in reply to ddr3500
    ...But maybe a guess...
    -Noel
  • Noel Carboni
    Dec 23, 2006
    Jul 16, 2012 10:08 PM   in reply to Noel Carboni
    In anticipation of your response...
    A Hard Round brush on a separate layer, followed by Layer - Layer Style, and inner and outer glows.
    -Noel
    Jul 16, 2012 10:09 PM   in reply to ddr3500
    ddr3500-
    try having the opacity and hardness of the brush set at the highest settings. it looks like you possibly had the settings in a low opacity and hardness.
    http://www.smashingmagazine.com/2009/11/16/brushing-up-on-photoshops-b rush-tool/
    and look at noel's advice above.
    -janelle
    Jul 17, 2012 12:20 AM   in reply to ddr3500
    Layer Style > Stroke with Fill Type > Gradient and Style > Shape Burst is another option.
  • Noel Carboni
    Dec 23, 2006
    Jul 17, 2012 6:36 AM   in reply to ddr3500
    I suggest you don't use the eraser for that - use a Layer Mask, and check the Layer Mask Hides Effects option in the Blending Options.  Paint black on the Layer Mask to hide pixels, white to reveal them, gray to partially reveal them.
    If you'd really rather "bake" the effects into the pixels and use the Eraser Tool, you can do that by choosing Rasterize - Layer Style:
    -Noel
    Jul 17, 2012 10:01 AM   in reply to ddr3500
    Make a new blank layer below palo 2, click back on palo 2 and choose Layer>Merge Down or Ctrl+E
    Or if you want to maintain the layer name, make a blank layer below palo 2, click back on palo 2 and beside the blank layer, click in the box just to the right of the eye icon on
    the blank layer to link the layers. Then go to Layer>Merge Linked or Ctrl+E
    Message was edited by: R_Kelly
    Jul 19, 2012 1:39 AM   in reply to ddr3500
    Because it's not a shape or type layer in photoshop 7, it's a pixel layer.
    Later versions of photoshop sometimes have different options.
    In fact if one were to look at the flatten layer effects script in cs6, it basically does what i posted in post #8.
    Jul 19, 2012 2:39 AM   in reply to ddr3500
    Using a layer mask as Noel suggested is the best way to edit the layer (hide parts of the layer), but if you still want to flatten the effects into your pixel layer
    you could record an action to speed things up.
    You can download the above action here:
    https://acrobat.com/#d=FFz-aQWnDgQKI0dSxvgFqQ
    After unzipping the file, load the action into the actions palette.
    Then target the layer with the layer styes and run the action.
