select query
Jul 17, 2012 1:47 AM
I am trying to output the value of each corresponding data column on unsaccountB tbl. However it returns with the name of the column not the value (newVal =). What is missing or I am doing wrong?
SELECT  p.firstname,p.lastname, u.XProxyContext, dw.[OldValue],newVal =
(select dbc.ColumnName from unsaccountB where dbc.ColumnName in
(SELECT name FROM sys.columns WHERE OBJECT_NAME(object_id) = 'unsaccountb') and u.AccountName = AccountName
  ,dwo.operationDate, dwo.OperationType,dbc.ColumnName,dbc.TableName
FROM DialogWatchProperty dw
  INNER JOIN DialogWatchOperation dwo ON dw.UID_DialogWatchOperation = dwo.UID_DialogWatchOperation
  INNER JOIN UNSAccountB u ON dwo.ObjectKey = u.xObjectKey
  INNER JOIN Person p ON p.uid_person = u.uid_person
  INNER JOIN DialogColumn dbc on  dbc.UID_DialogColumn = dw.UID_DialogColumn
where ---OperationType = 'U'
  dwo.operationDate between convert(varchar,@sDate,1) and convert(varchar,@eDate,1)
  ----And dbc.ColumnName = u1.
  And u.XProxyContext = @TargetSystem
  And p.FirstName = (case when @FirstName <>'' then @FirstName else p.FirstName end)
  And p.LastName = (case when @LastNamea <>'' then @LastName else p.LastName end)
  And p.CentralAccount =
  (case when @userName <>'' then @userName else p.CentralAccount end)
  And PersonnelNumber = (case when @personelNumber <>'' then @personelNumber else PersonnelNumber end)
order by firstname,lastname,dbc.ColumnName asc, dwo.operationDate desc
Output Data:
firstname lastname XProxyContext OldValue newVal operationDate OperationType ColumnName TableName
Özlem Karaman FINSOFT FINSOFT/FINSOFT/Özlem Karaman CanonicalName 2012-07-12 11:40:19.283 U CanonicalName UNSAccountB
Özlem Karaman FINSOFT FINSOFT/FINSOFT/TEST ÖZLEM SOYADI 35474 CanonicalName 2012-07-12 11:36:59.050 U CanonicalName UNSAccountB
Özlem Karaman FINSOFT Özlem Karaman cn 2012-07-12 11:40:19.283 U cn UNSAccountB
Özlem Karaman FINSOFT TEST ÖZLEM SOYADI 35474 cn 2012-07-12 11:36:59.050 U cn UNSAccountB
Özlem Karaman FINSOFT CN=Özlem Karaman,CN=FINSOFT,dc=finsoft DistinguishedName 2012-07-12 11:40:19.283 U DistinguishedName UNSAccountB
Özlem Karaman FINSOFT CN=TEST ÖZLEM SOYADI 35474,CN=FINSOFT,dc=finsoft DistinguishedName 2012-07-12 11:36:59.050 U DistinguishedName UNSAccountB
Özlem Karaman FINSOFT TEST ÖZLEM FirstName 2012-07-12 11:36:59.050 U FirstName UNSAccountB
Özlem Karaman FINSOFT Karaman LastName 2012-07-12 11:40:19.283 U LastName UNSAccountB
Özlem Karaman FINSOFT SOYADI 35474 LastName 2012-07-12 11:36:59.050 U LastName UNSAccountB
    Jul 17, 2012 1:59 AM   in reply to emmim44
    This isn't a CF question, it's a SQL Server question.  There is absolutely nothing relating to CF in your question.
    You're better off asking this on a SQL Server forum.
    In the meantime, google up how to reference a column name dynamically in SQL Server.  That's the bit you're missing.
    This code:
    Just returns the column name, not the content of the column (which I guess you know, but that's the bit you need to focus on).
    Adam
