Curious, why would someone choose to build a 2048x1536 InDesign doc instead of 1024x768? Is there some sort of advantage I'm not picking up on?
Careful: you need to distinguish between the size of the InDesign document and the size of the folio. There is no advantage to creating an InDesign document larger than 1024x768. When you create your folio in Folio builder you can specify 2048x1536 as the dimensions to get a folio with high enough resolution for the new iPad, using the source InDesign document that was done at 1024x768.
Neil
I'm concerned more with the larger layout -- when I export a 1024x768 file up to 2048x1536, having the images not look high-res enough.
I realize Adobe's recommended workflow is to design at the 1024 size -- mostly, it seems, so that all our 'old' rules about pixel dimensions for fonts and whitespace are still true (body copy should be 16pix), and we don't have to recalculate what we already know. But I come from a print design background, and don't have the preconceived rules. So I can't wrap my head around why I would design for the smaller size and cross my fingers that it looks good when it scales up? Why not just design for the larger resolution and have it scale down? It's all a matter of proportion, right?
And if the answer is still that I should design at 1024x768, what resolution images should I be placing in that indd file to make sure they look good on a retina screen export?
Have you gone through our DPS publishing guidance for iPad? Check out http://wwwimages.adobe.com/www.adobe.com/content/dam/Adobe/en/devnet/d igitalpublishingsuite/pdfs/dps-ipad3-bestpractice-apr2012.pdf, I believe it will help with your questions.
Either approach you take (design big or design small) I believe you still wind up having to cross your fingers
You are either betting that InDesign will scale down properly, or betting InDesign scale up properly.
Neil
Sorry to drag up an old thread but I'm just getting my head around all this.
Can you confirm if what I've got below is correct. I'm a print designer traditionally so have kind of taken it back to a physical way of thinking.
Working on the long edge:
iPad 1&2 is 1024px @ 72ppi (this works out with a document of 361.2mm)
iPad 3 is 2048px @144ppi (this works out with a document of 361.2mm)
So in essence, if you are thinking in print terms, we are creating a document of 361.2mm for both versions but placing different resolution images placed in. i.e. iPad 1&2 drop in images with 72ppi @ 100% and for the iPad 3 images with 144ppi @ 100%.
Obviously the document is set up at 1024x768px not in mm.
Convoluted? Yes, but I now have a grasp on how it works instead of doing what I'm told.
