I was working on a short story script this afternoon at the office. I saved it (at the bottom) and closed story plus down (I have the creative cloud). When I got home, I decided to do a little more work on my script and it was gone. It was stored in my Healthy People Now project folder with a script named Evermore. I believe the name of the lost script is Pardon My Smoking. I do not have time to hunt for scripts, nor do my students. If these kinds of problems are not worked out, I will not be able to use this in my classroom.
Another complaint I have with story is that it is not intuitive. I usually have no right-click options (PC) as I do in many other Adobe applications. I use just about every application in the creative cloud (with the exception of the flash programs)---PS, AI, ID, Premiere Pro, AE, Speedgrade (which is also horribly difficult to understand and use), Encore, Audition, Soundstage etc., I also teach many of these applications. I believe that Adobe should be cross-compatable with feature similarity across platforms. I realize that this is an extremely difficult request, but considering that people who work with story, speedgrade, premiere, and AE are generally going to have to learn a complete set of different commands/features/etc. it would be nice if it were easier to move from one program to another without having to change your whole thougt pattern as you do between speedgrade and say, premiere pro.
Hi.
I apologize for the inconvenience. Can you confirm that:
1. Were you working in the desktop application in the office?
2. Were you working online when you saved the script?
3. Can you see the script when you use your office computer?
4. Do you see the script at all in the project when you log in from home?
5. Are you using the desktop application at home and are you online?
--Anubhav
Please send
- Your AdobeID (username which you use to login to story),
- Script name (which is missing),
- Approximate number of pages in it (when last saved)
at "adobestory-support@adobe.com".
Ratnesh
rhague@prcc.edu is my user name
I think the script name was Pardon My Smoking (but I'm not quite sure)
I don't think it was more than 5 pages.
I have checked my office computer and it is not here.
Ronn Hague
Digital Media Coordinator/Museum Director
Pearl River Community College
Hancock Hall
101 Highway 11 North
Poplarville, MS 39470
office: 601-403-1316
fax: 601-403-1035
cell: 601-365-3227
Can you see if the script ‘Pardon my smoke’ is in the sync issues folder ?
This folder is located on the left side panel in “projects view”.
For more details on how to locate “sync issues folder” see page-8 (image tag – F) on this pdf<http://help.adobe.com/en_US/story/cs/using/adobe_story_help.pdf>.
ratnesh
I just found it in my deleted items folder. I DID NOT delete it. I will, from this point onward, save to disk. This seems to be the only way to save my scripts safely...hopefully. I have about 40 hours invested in one script. I do not want to lose that. Can you guarantee me that this will not happen with my script?
Ronn Hague
Hancock Hall
fax: 601-403-1035
cell: 601-365-3227
Basically, it does not have the "feel" that other Adobe programs have. It could use some more drag and drop features, more like explorer (microsoft) so that you can move one script into another section or out of a project and into a new project if necessary. I noticed that the projects do not allow me to place multiple projects into folders within the explorer in Story. That ability would also be nice. We have a program called Healthy People Now that we produce about six short films per year for inclusion into K-12 schools that I would like to be able to group. Maybe I am just overlooking this feature.
Ronn Hague
Hancock Hall
fax: 601-403-1035
cell: 601-365-3227
Ron.
All these feature are in the program. You can use Categories as a parent folder for multiple projects. Click on the arrow icon next to projects in the projects view and select new category. Now, create a new category and drag drop projects into it.
You can also drag drop scripts from one project to another.
Sorry this is not as intuitive as you’d like it to be.
--Anubhav
Thanks so much. I was hoping you had already addressed or would address some of these issues. I expect as time goes by, you will address more. I really love some of the features. Some of the features require a bit more of a learning curve than I may want to invest due to time constraints. One such feature is the ability to synchronize both shooting and cast scripts so that any change in dialog or action on one reflect on the other without having to be a computer whiz to do so.
These are the instructions. Most people would just shake their head and walk away:
We understand the frustration and I think I have a workaround for the problem. You need a use a different template (attached) so that there is enough space to fit the camera lines.
Save the shootingscripttemplate.xml file on your local drive
Open a film script
Click anywhere you want to add a shot
Go to the production menu and select Production ->Camera shot
Choose Continue, when you are prompted to save the file as different version of the script (not saving it as a different version)
Enter information about the shot and click ok
Notice that the script format has changed and your shot appears on the left.
From the View menu deselect the camera shots option
Now go to the Edit Menu and Select Edit->Template
Choose "Film" template from the drop down to revert back to the original formatting of the script with the camera shots in it.
Your script should now look like this:
Choose Edit->Template again and now import the attached template so that you can view the same script as a shooting script.
The imported template will autoload values into the template.
From the View menu and select the camera shots option. Your script should now look like this
Switch between templates when you want to work on camera shots and when you dont.
You can add the shooting script template to your favorite templates by:
1. Go to the projects view
2. Clicking on the new button on the top right hand side of the screen
3. Select a film script from the drop down.
4. Click on the change template button
1. Now click on import and select the shooting script template from your drive. Click ok and then ok again
2. Click cancel
3. The shootingscripttemplate is now available in the drop down when you go to Edit->Template from the authoring view of a script.
As you can see this is a bit much for the average screenwriter or filmmaker to learn on top of every other program, codec, etc. that we have to know.
Ronn Hague
Hancock Hall
fax: 601-403-1035
cell: 601-365-3227
