kim shep
Best way to animate a line with a dot leading along a path
Jul 17, 2012 9:14 AM
I need to animate a line along a path with a circle in front of it. Basically an 'i' path with the tail extending. Similar to the shape in this image http://www.ravishankar.me/images/intro/skelta-connect2.png
Ive tried:
Using and animating a shape tween, its very time consuming and would only really work without the dot
Using a mask doesnt seem to work either as its not a basic line
And making it a symbol on a path in a motion tween also doesnt follow the line to how i need it
Any suggestions please!?
    Jul 17, 2012 10:15 AM   in reply to kim shep
    You could do a frame by frame animation.  The easiest way to do it is to work the animation backwards along the timeline, removing a piece of the line (and moving the dot) in each frame and then reversing the frames when you are done.
    Jul 17, 2012 10:31 AM   in reply to Ned Murphy
    In addition to Kglad's suggestion, I would separate the dot from the line on to its own layer. Convert the dot to a symbol and motion tween it. As for the line, use the frame by frame method Kglad mentioned or an animated mask.
    Jul 17, 2012 11:55 AM   in reply to chris georgenes
    pssst... I'm not kGlad
    Jul 17, 2012 12:47 PM   in reply to Ned Murphy
    Oops! I swear it showed you as Kglad when I first posted that - ok, i'm old, chaulk it up to tired eyes. Sorry Ned!!!
