FlashKatt
Can't move objects small distances
Jul 17, 2012 11:26 AM
CS6, OS X
I can't seem to move objects in my drawing small distances..I'm used to being able to do this..must be some setting I hit, but I can't find which one it might be. I have snap to off, but this isn't behaving like snap to..it's behaving like I'm only "allowed" to move objects certain distances; any smaller and the object simply doesn't move at all..
can someone shine a light on this?
thank you!
kat
    Jul 17, 2012 11:31 AM   in reply to FlashKatt
    kat,
    Untick Align to Pixel Grid in the Transform panel, and untick it for new documents if you want to avoid it in the future.
    The setting is default for formats meant for web and (similar)) devices.
    Jul 17, 2012 11:44 AM   in reply to FlashKatt
    kat,
    While I was unable to un-tick this setting,
    Was it unticked?
    If so, it may be some snapping that should be unticked. I am unsure about all the options (in CS6), but a search in the Helpfile should reveal them.
    Jul 17, 2012 11:47 AM   in reply to Jacob Bugge
    It's an object based setting. You have to untick it for new objects and you have to untick it for existing objects.
    and @FlashKatt read this: http://blogs.adobe.com/infiniteresolution/2009/05/startup_profiles_a_g reat_tool.html
    Jul 17, 2012 12:08 PM   in reply to FlashKatt
    Thank you for the added knowledge, Monika,
    from someone a bit slow on upgrading.
    Jul 17, 2012 12:42 PM   in reply to FlashKatt
    FlashKatt when you create a new Doicument such as a web document uncheck the option in the new document options dialog and it then will not be a problem for that document it is a default settings for a couple of the sandard document types that are rgb based.
    Always check to see if the option is on when creting a new document.
    Also be aware if you are actually creating a web document then the option is actually useful as it will prevent you from creating and aligning elements that will not work on the web as you intend.
    Rememebr there is no fraction of a pixel on the web only whole pixels.
