roborighter
large tables truncated or withheld from webhelp
Jul 17, 2012 12:04 PM
Tags: #table #robohelp_8 #webhelp
I'm running into a major issue trying to include a large table in my WebHelp build.  I'm using RoboHelp 8 in Word.  When I include a large table (6 columns x 180 rows) the table is either truncated or withheld from the compiled WebHelp.
I've tried several things to resolve it, but they all end in the same results.  I've tried importing the table from its original Word file.  I've tried breaking it up into many smaller tables.  I've tried building a new table in Word, then copying the data.  Oddly enough if I build the table blank and compile--the table appears.  But once I copy data into the table, it disappears.
RoboHelp seems unable to process the table, as when I've broken the single table into several smaller tables, it chokes, doesn't include the table or even put the topic in the TOC, even though it is in the source file.
Any ideas?  I've not been able to find anything in the forums or anywhere else online.
Many thanks!
  • RoboColum(n)
    Oct 8, 2004
    Jul 17, 2012 12:56 PM   in reply to roborighter
    Can you tell us what you mean "using RoboHelp in Word"? Do you mean you are using it as your editor or that you are using the RoboHelp for Word application? If the later, is there a reason why you can't use the RoboHelp HTML application? This is much more suited to producing WebHelp. Personally I wouldn't touch the HTML that Word creates with a bargepole.
  • RoboColum(n)
    Oct 8, 2004
    Jul 17, 2012 2:48 PM   in reply to roborighter
    IMHO I think you should revisit RH HTML. Why create HTML pages with a tool not designed for doing so. Take a long hard look at the HTML code created by Word and you'll quickly want to run a mile. Having issues with a table could be only the start of your problems.
