IvyLeafLA
InDesign CS6 Hyperlinks palette is blank, how do I change this?
Jul 17, 2012 12:45 PM
Tags: #hyperlinks #indesigncs6
I'm working in InDesign CS6 on a new Mac Powerbook.
I created hyperlinks in an InDesign CS3 document (last year) which I brought into CS6 today.
My hyperlinks do not apear in the control panel (as a list), but I see the highlighted links in the document and they are active when I save to pdf.
I'm including one additional comment - even though I marked the hyperlinks with invisible boxes, I'm still seeing outlines around the links.
I'm hoping once I have the panel with the list of links I can adjust the look on the page, too.
Is there a way to set the control panel back to a default setting?
Merci beaucoup!
    Jul 17, 2012 12:59 PM   in reply to IvyLeafLA
    I just tested with InDesign CS3, created a few hyperlinks, opened the file in CS6 and all the hyperlinks are still there. No problem.
    How did you open the CS3 file? Did you use the INX export format for exchange?
    Can you provide a sample document for downloading?
    Uwe
    Aug 23, 2012 11:36 PM   in reply to IvyLeafLA
    I have the same problem. Tried resetting my preferences but it hasnt helped.
    Solved It!!
    Seems like my workspace profile was corrupt. I changed from my personalised profile to "Interactive for PDF" ( which has the Hyperlinks panel) and it worked. All the Hyperlinks and cross-references show.
    Now i am going to rebuild and save my profile
    Nov 2, 2012 11:13 AM   in reply to IvyLeafLA
    I had the same issue with my Hyperlinks palette -- very frustrating -- but the solution does not require trashing (and laboriously rebuilding) your profile.
    Open the drop-down menu on the Hyperlinks palette (as you would to "Edit Hyperlink") and click "Small Panel Rows" at the very bottom.  The Hyperlinks section should reappear.
    It took me 2 hours and 3 times rebuilding my profile before I tried that out of desperation
    Now I'd like to know exactly how to get rid of the "Cross-References" section of that palette.
Bookmarked By (1)
