auto-save doesn't always auto-save???
Jul 17, 2012 4:50 PM
Tags: #premiere #glitch #auto-save
Mac 10.7.4
CS 6.0.1
Just had an AWESOME double whammy kernal panic / no auto-save. A good 25 minutes of work... down the toilet. YAY!
The curious thing is though... that my auto-save settings are set to save every 10 minutes. So, that my last auto-save file was a whole 25 minutes prior is to say the least, troubling. How could this have happened? And how do I make sure it never happens again. I really MUST have auto-save every 10 minutes. It's the last line of defense to cushion the blow of these egregious instability issues on mac. If premiere takes that away from me too, I don't know what I'll do.
Help?
    Jul 17, 2012 5:33 PM   in reply to dv416
    I did some testing with auto-save and found a situation which may have affected you.
    Adobe changed the way auto-save works with CS6 - in previous versions when it hit the auto-save inteval, it would stop playback (and anything else you were doing) to fire off a save.  This was a terrible solution, since AS should not interrupt your work.  Now with CS6, it will not interrupt your playback, but it is still not smart.
    If you are playing back your sequence during a time when the AS should fire off, then AS will wait until the next interval comes around.  However, if you happen to be playing your footage at that time as well, then it start over and wait again for the next interval - so, in effect, you can be cancelling out your AS by playing your footage during each AS interval.  Completely terrible.  If AS was smart, it would be a background process which would look for a downtime moment to do its job.  I would be totally fine with waiting for the AS to finish right after hitting stop on my sequence, for example.
    So, I don't know if this is what happened to you, but it is a culprit.
    Jul 17, 2012 6:30 PM   in reply to dv416
    Interesting what users want.
    There is an active thread, where users do NOT want AutoSave to kick in, while doing something else. Here, users DO want it to come into play, when doing something else.
    Now, I am not saying that there should not be possible toggles, but I am not sure that Adobe can please everyone, all of the time.
    Hunt
    Jul 17, 2012 7:24 PM   in reply to Bill Hunt
    Auto save drives me insane
    Jul 17, 2012 9:13 PM   in reply to Bill Hunt
    Bill,
    I think Adobe had it wrong in previous versions, changed it for CS6, and still has it wrong.  The users on the other thread are (rightly) complaining about how it used to interrupt playback, and I feel like the way it is implemented now is a bit better, but ultimately unreliable as described above.
    The smart way it can be implemented (which FCP and Avid already figured out) is to not have AS interrupt playback, but be smart enough to not miss an AS interval - in practice this would mean that if playback is occuring during an AS interval, immediately upon hitting the spacebar to pause playback, the AS would kick in, utilizing the brief moment of downtime.
    Of course AS needs to use resources and lock out the user for a brief moment, but Premiere can be much smarter about when to take over and be reliable at the same time...
    Feb 7, 2013 10:52 AM   in reply to Bill Hunt
    Autosave doesn't seem to be working on my Mac: 10.8.2 PrP 6.0.2.
    I crashed PrP by keyframing position on a large .jpg, and then turning off the keyframes. After the crash, the autosave's most recent version was an hour old. I have autosave set to 20 minutes.
    My project is only 12 minutes long, so the playback-delay-save theory does not work.
    Also, I saw the autosave progress bar. It seems to ber saving.
    Anybody have a suggestion aside from buying a PC?
