Which Brush or Other Tool Can do This (see sample)?
Jul 17, 2012 6:57 PM
Hi Again;
I realize that I'm trying to circumvent the normal method of learning CS5, but I am interested in knowing a bit about (I presume) brush tools.
The simplest way to explain this is to show what I'd like to be able to do. Here's my example:
Please forget about the slight curving of the lines, and pretend they're straight. I'm more interested in the fact that one colour stops in a less-than-sharp way, then becomes another colour. It literally looks like I dipped a narrow brush in paint, stroked it left to right across canvas until the brush started to run out of paint. I like this effect, because it's an artistic way of transitioning from one colour to the next.
If you had to make this, using Illustrator CS5, is this doable? Which brush or other tools would work the best for this?
Thanks for any help, and for helping with my previous Warp Effect question.
Cheers, Tom.
    Jul 17, 2012 8:41 PM   in reply to Tom C. Kay
    Not exactly like your sample, but try these,
    Jul 19, 2012 9:06 AM   in reply to Tom C. Kay
    Drag the brush from the Brushes panel and drop it on the document. Select each color/shade and change as desired. To crop you can select all paths of the brush and use the Eraser tool, holding Alt will allow you to erase with a selection rectangle. When done, select all paths of the brush  and drag it back to the Brushes panel. In the New Brush dialog that appears select Art Brush.
    Jul 19, 2012 9:51 AM   in reply to Tom C. Kay
    After you select the brush, try selecting the color you want the line to be. The watercolor brushes I tried are set to use Tints. By double-clicking on the brush in the Brush panel you can get the Settings dialog. You might try using Tints and Shades from the dropdown at the lower right.
    Jul 19, 2012 10:17 AM   in reply to Tom C. Kay
    Also, you can overlap brushes and use different Opacity and color modes from the Transparency panel.
    Jul 20, 2012 2:42 PM   in reply to Tom C. Kay
    Pantone colors represent Pantone inks. Pantone makes and sells to offset printing shops 13 inks with basic colors and they also sell a swatch book called Pantone Formula Guide with all Pantone colors that can be made by the printing shop by mixings percentages of the 13 basic inks as specified in the formula guide.  Each Pantone color is printed on the offset press by using a separate plate. If you send a file for offset printing with a transparent Pantone color overlapping another, the overlapped part of the underlying pantone color will be screened and the transparent pantone color on top will print over it with screening to. You can see that in Illustrator if you open the Separations Preview panel and hide (click the eye) of the transparent pantone color on top.
    If you are using any other printer than offset press, you are not going to have pantone inks but CMYK or RGB values sent to the printer and your pantone colors will be converted at print time. Which is the same as using CMYK or RGB values converted for the color space of your printer from the pantone colors.
