Passing CF variables in soap request
Jul 3, 2012 9:35 AM
  Latest reply: BKBK, Jul 17, 2012 11:14 PM
Replies 1 2 Previous Next
    Jul 14, 2012 3:43 AM   in reply to Emily LaMunyon
    Based on the information you've just provided, I will advise you to ignore my suggestion about the query. If, as you say, the file ID is coming in via the URL
    http://localhost/coldfusionpage.cfm?subdir=23&page_id=624010.pdf
    then simply replace
    <cfset fileID = "624010" />
    with
    <cfset fileID = listGetAt(URL.page_id, 1, ".") />
    That is dynamic enough. With no CPU-consuming query in sight!
    Jul 17, 2012 11:14 PM   in reply to Emily LaMunyon
    Emily LaMunyon wrote:
    So I tried your suggestion and the API seems to not like using this <cfset fileID = listGetAt(URL.page_id, 1, ".") />
    Pease expand on what you mean by "seems not to like". If the code
    works, then I expect
    to work, too.
    I assume that you intend, in every case, to extract the fileID from the file-name of the PDF that comes in through the URL. In the URL you've given, that file-name is the variable URL.page_id. Its value is "624010.pdf".  You could treate this as a list with delimiter ".". In that case, "624010" will be the first list element. This is what the last line of code does.
1 2 Previous Next
