Possible:Booleans in Arrays?
Jul 18, 2012 2:27 AM
I would like to use an array to A)define the Boolean state of a group of variables and B) check those variables. I have tried a bunch of different methods of doing this but get a bunch of different errors. Is this actually something that's possible? What would sample code look like?
    Jul 18, 2012 3:02 AM   in reply to witherton
    definately possible, several different ways of doing no different to anything else really
    post code and errors for specific help
    var i:int = -1
    var boolArray:Array = [true, false, 3>2, true, false, false, i == -2, true];
    trace("4th bool: " + boolArray[3])
    if (boolArray[2])
              trace("3rd bool is true");
    else
              trace("3rd bool is false");
    Jul 18, 2012 4:06 AM   in reply to witherton
    then you can just use buttons[i] = false;
    and
    if (buttons[i] == true) {trace("true")}
    (note using single = is an assigment not an equality)
    here is another demo that might help
    package
              import flash.display.Sprite;
              public class Main extends Sprite
                        private var buttons:Array;
                        public function Main()
                                  buttons = new Array();
                                  setUpButtons(6);
                                  testButtons();
                        private function testButtons():void
                                  for (var i:int = 0; i < buttons.length; i++)
                                            if (buttons[i])
                                                      trace("button " + i + " is true");
                                            else
                                                      trace("button " + i + " is false");
                        private function setUpButtons(len:int):void
                                  for (var i:int = 0; i < len; i++)
                                            buttons[i] = false;
    Jul 19, 2012 12:52 AM   in reply to witherton
    that will work but is not the case if you want to paste your code here I can get it to work without the variables first
