jamesd3rd
Blurry images when zooming in Survey & Grid View
Jul 17, 2012 11:55 PM
When I am in Survey View and hit the Z key, some of  the previews are blurry.  The same thing happens in Grid View.  However, in Loupe View, the images are fine when I the 'Z' key.  Using Survey View would make things go faster when making my picks.  Any ideas why this happens?
I tried rendering 1:1 but the returns a mesage that says renders are up to date and rendering was done.
  • Victoria Bampton
    Apr 1, 2008
    Jul 18, 2012 4:09 AM   in reply to jamesd3rd
    I can't replicate the issue here James.  Which OS and which LR version?
    Jul 18, 2012 5:44 AM   in reply to Victoria Bampton
    This is definitely a bug. I can see it too, and it's little bit annoying. LR 4.1, Win7 x64.
    To reproduce just select two images, render 1:1 previews to be shure they are present.
    Then press 'N' to switch to Survey mode, and now press 'Z' to zoom in active photo.
    It gets zoomed, but looks like LR zooms in standard (smaller) preview instead of using 1:1 preview - the result is blurry and a little pixelated, it definitely lacks resolution.
    But when in the Loupe view (switch view using 'E') and zooming all work just fine - the image is at full resolution and is sharp.
    And even if I switch from Survey to Loupe with zoomed in image - it still stays blurry.
    To get sharp image I need to zoom out and then zoom in again.
    So in short - it looks like 1:1 preview is used only when image is zoomed in from the Loupe view.
    Jul 18, 2012 6:08 AM   in reply to jamesd3rd
    I reported this (Windows only, I think) bug a while back.
    Jul 18, 2012 9:21 AM   in reply to jamesd3rd
    I have a similar problem on a Mac (LR 4.2 - Lion, iMac 27). When I zoom in the loup mode at 1:1 the image often does not sharpen up (seems inconsistant). If I then move to the Develope module, and wait for "loading.." to occur, it will. Then I can go usually go back to loup mode if I choose. It's annoying but haven't spent the energy to try and determine the pattern.
