piggysmile
How do you access a child element in Actionscript 2?
Jul 18, 2012 6:38 AM
Tags: #movieclip #actionscript_2
I have the following Flash structure.
Main Timeline
---test_menu (Movie Clip)
------test_menu_sub (Movie Clip)
---------submenu_item (Button)
On Main Timeline (2nd frame), I added this code:
test_menu.test_menu_sub.submenu_item.onPress = function () {
      trace("clicked");
However, this doesn't work. Please see the following files for reference. Any help will be appreciated.
  • kglad
    Jul 21, 2002
    Jul 18, 2012 7:03 AM   in reply to piggysmile
    if that code doesn't work, you probably have an incorrect path/name.  to test if that is the issue, use:
    trace(test_menu.test_menu_sub.submenu_item)
    to see is the movieclip is found.  if not, you have an incorrect path/name.  if it is, you are not clicking that button.
    Jul 18, 2012 7:08 AM   in reply to piggysmile
    Change your textfields to be non-selectable and see if that helps.  HAving them selectable can block interaction.
    Jul 18, 2012 3:22 PM   in reply to piggysmile
    No, non-selectable means setting it to be non-selectable in the Properties panel.  If you see the i-beam when you hover over the textfield, its text is selectable
  • kglad
    Jul 21, 2002
    Jul 18, 2012 3:39 PM   in reply to piggysmile
    then you're not clicking that button.  there are a number of ways that can happen some of which are subtle like when you use timeline tweens.
