Hello, I have just upgraded to CS6, and I am having a lot of trouble with the display settings. In preferences - display performace i have the settings on "High" but when i zoom into the document or even move it slightly to the left or right or even make a tiny alt such as change some text - indesign puts it into a "fast display" mode and stops viewing things like the drop shadow.
When I right click on an item / block of text and go to display - it is still on "high"
It is on all documents that i bring into CS6 indesign and also still happens on new ones created from CS6.
It never did this on previous versions. before I could chose to display high and it would!
Please help.
If it's for every document, old and newly created - try resetting your preferences
http://forums.adobe.com/thread/526990
If it's only in one document try fixing corruption in the document
http://forums.adobe.com/thread/526991
See if that helps
Hi in windows 7 when you go into C:\Users\User there is no AppData after that? so couldn't do that method,
but did it your other way, (holding cntl, alt and shift) and that worked sort of ... except it has now knocked out my mouse preferences. Does indesign CS6 not support side-scroll mouses with zoom? When I put the side-scroll and zoom options back onto the mouse (instead of just standard up and down) the display goes back to "fast view" again in Indesign?
I have a logitech LS1 mouse and windows 7.
thanks
This is the first I've ever heard of an issue with a mouse causing issues.
I'd try:
A different mouse
A different Driver for the mouse causing the issue(check the logitech site or talk with their support)
I'd try turning off Aero in the Windows http://www.howtogeek.com/?post_type=post&p=216
See if those help
I also use Logitech mice (currently an LX3) on Windows 7, and I frequently get a low-res preview (in all versions of ID) after side scrolling with the wheel. I would say the display is more like "typical" rather than "fast," though -- fast is gray boxes instead of image previews.
ID and mice just don't seem to always get along. Ask users of the Mac Magic Mouse.
I've found I can "fix" the problem by pressing the Alt + Spacebar to get the hand tool and click anywhere, or use the hand tool or one of the window scroll bars to move the view. In some versions the "cure" sticks for the rest of the editing session on that file.
Peter, thankyou. that worked great!
The mouse worked perfectly well in all other adobe programmes except indesign so was dubious it was a mouse problem. Turning off Aero also made no difference.
But the Alt and Spacebar def worked great!
Have just gone from Mac to PC and the side scroll on the magic mouse i found was tempremental, hence going with the side scroll that works great in illustrator, was just surprissed to have such a problem with it in indesign.
thanks tho,
very helpful!
Hello, after contacting Logitech, and trying numnerous different solutions, they have come to the conclusion that Adobe is the issue as I suspected and have received the below message from Logitech:
Adobe products as well as some CAD programs are somewhat special snowflakes when it comes to how they expect button assignments to be handled and they sometimes do not play nice with SetPoint. The problem is without any input from Adobe or whichever company makes the software we cannot fix the issue because we do not know what is causing the issue, we are not familiar with the coding of this software.
So unfortunately, Adobe would need to contact Logitech with this and provide pointers, otherwise this and other issues cannot be fixed.
Can you please let Adobe know and ask Adobe to contact Logitech?
Do you know how I contact Adobe with the above and to who exactly?
thanks, Sara.
You can use the bug form: Adobe - Feature Request/Bug Report Form, or if you want to spend some money open a support case so you get to talk to someone and get a case number. Whether that would get you more attention, I can't say. If you are paying for a service contract already, I'd definitely open a support case, though.
