vector. error 1046. Type was not found or was not a compile type...
Jul 18, 2012 7:32 AM
Type was not found or was not a compile type constant at compile time.
BUT I have imported import flash.display.MovieClip; amd my vector variable declaration is correct.
private var myVect:Vector.<MovieClip >  = new Vector.<MovieClip > (5,true);
I am even copying and pasting from a tutorial so this is very strange.
  • kglad
    Jul 21, 2002
    Jul 18, 2012 8:26 AM   in reply to codeBeastAdobe
    copy and paste the error message.
    Jul 18, 2012 8:30 AM   in reply to codeBeastAdobe
    try
    private var myVect:Vector.<MovieClip> = new Vector.<MovieClip>(5,true);
    Jul 18, 2012 11:04 AM   in reply to codeBeastAdobe
    that is not exactly the same code that I posted
    You need add:
  • kglad
    Jul 21, 2002
    Jul 18, 2012 11:10 AM   in reply to codeBeastAdobe
    tick file/publish settings/swf and tick "permit debugging".   take a screenshot showing the error message and attach it here.
    take a sceenshot of the first 20 or 30 lines of that class showing you import statement and class name.  attach it here.
  • kglad
    Jul 21, 2002
    Jul 18, 2012 11:44 AM   in reply to codeBeastAdobe
    that error message won't be triggered by anything you've shown.
    tick file/publish settings/swf and tick "permit debugging".   copy and paste the complete error message
  • kglad
    Jul 21, 2002
    Jul 18, 2012 3:43 PM   in reply to codeBeastAdobe
    there's another as3circle class being used by whatever fla you're using to test.
    if the code you've shown has been saved to as3circle.as, try using a new directory to save your fla and your class.  if you haven't saved your shown code to that file, save it and retest.
  • kglad
    Jul 21, 2002
    Jul 19, 2012 6:07 AM   in reply to codeBeastAdobe
    you're welcome.
