longzhilin
How to map a mono audio track to left or right channel only in CS6?
Jul 18, 2012 2:24 AM
Guys,
I imported a mono audio clip and get onto mono and stereo audio track, but I can't make it outputing to left or right cannel only on both of them.
And I can't add "Balance","Fill left" and "Fill right" effect to it. So what should I do in this situation? I would like to output this mono audio clip to left or right channel only.
I am using Premiere CS6.
Thank you!
Nick
    Jul 18, 2012 3:09 AM   in reply to longzhilin
    From the project panel (before you put the clip on the timeline) right click on the clip, select Modify/Audio Channels and set it up to stereo.
    Jul 18, 2012 10:08 AM   in reply to longzhilin
    Why not?
    Jul 19, 2012 2:49 PM   in reply to longzhilin
    Balance is one of the "fixed effects" attached to every clip in CS6.  You should be able to just pan it as desired.
    Jul 19, 2012 7:08 PM   in reply to longzhilin
    It's already there in the Effects Control Panel for each clip, like Motion and Volume.
    Jul 20, 2012 8:14 PM   in reply to longzhilin
    Yep.
    Jul 20, 2012 8:17 PM   in reply to longzhilin
    The Panner is a fixed effect on all audio clips but the "Balance Control" is not included on Mono audio clips.
    Jul 22, 2012 7:44 PM   in reply to shooternz
    It is for mine.
    Jul 22, 2012 8:12 PM   in reply to Jim Simon
    It is for mine.
    So out of interest...what does it balance in a Mono Track?
    I would test it ...but like the OP..dont have the function.
    Jul 23, 2012 10:55 AM   in reply to shooternz
    Well, assuming a stereo Master, it balances to the left or right as set.
    Jul 23, 2012 1:16 PM   in reply to Jim Simon
    A mono audio clip is not in stereo by definition.
    Jul 23, 2012 3:19 PM   in reply to shooternz
    Granted, but it can be panned to either the left or right Main channel.
    You never used an audio mixer before?  Mic inputs are mono, but they can all be panned to either side of the Master bus.  Same concept inside PP.
    Jul 23, 2012 3:26 PM   in reply to Jim Simon
    Jim
    You get both a Panner and  Balance on a Stereo Track.
    You Get a Panner on a Mono Track but not a Balance
    Is that different on your system?
    Jul 23, 2012 5:28 PM   in reply to shooternz
    The effect is called Panner for all clips.  Twirl it down and stereo originals have a balance control, mono have a pan control.  This is the same as you see on a mixer.
    So, if you pan left, then the mono audio only comes out the left channel.
    Jul 23, 2012 6:38 PM   in reply to Jim Simon
    We knew how they worked... but  now you have confirmed what we have been saying.  Thanx.
    Jul 23, 2012 7:11 PM   in reply to shooternz
    OK, so I got the name wrong.  But the end result is the same whatever you call it.  Sound can be directed to either side of a stereo Master with the built-in Panner effect.  There's no need to Modify anything.
