kpluck
InDesign CS6 crashing on page(s) deletion
Jul 10, 2012 3:33 PM
Tags: #indesign #crashing #page #deletion
Using OS X Lion (latest version) on a new MacBook Pro 15 (not the retina model) and InDesign CS6. Whenever I try to delete a page, or pages, from any document InDesign crashes.
If I manually delete the objects from the page(s) first and then delete the page, it doesn't crash.
This has been happening on a wide variety of existing documents (CS5 ver) as well as newly created CS6 documents.
Any thoughts?
-Keith
    Jul 11, 2012 2:04 AM   in reply to kpluck
    Same problem here. I'm using a new MacBook Pro 15" Retina. I'm using the latest Indesign CS6 with all updates installed and OS X Lion 10.7.4.
    Any thoughts about a solution for our problem??? Anyone else experiencing this?
    Best,
    Steffen
    Jul 11, 2012 3:01 AM   in reply to skraegelin
    BUG: Having the same problem here!
    (MacBook Pro 15" Retina // OS X Lion 10.7.4 // Latest CS6 Master Version)
    Tip to avoid crash:
    The only solution I've found is to delete all the content of the page/s first and then delete the page/s. Annoying - i know.
    J
    Jul 11, 2012 4:55 AM   in reply to jan.koenig
    I found a similar thread, and wonder if its the same issue: http://forums.adobe.com/thread/1024105?start=0&tstart=0
    Jul 11, 2012 6:46 AM   in reply to Vikrant Rai
    There is a big problem with indesign and the latest version of 10.7.4
    Anytime a warning box pops up, it causes indesign to crash. So when deleting a page with content, it warns you about losing it all. I was getting it when packaging files, or even trying to make a custom page size in the print dialogue window. Its pretty wide spread and very very annoying. Hopefully Adobe gets this sorted asap.
    Jul 11, 2012 7:37 AM   in reply to wonderings1111
    While I won’t eliminate anything I think you might want to let Apple know, too.
    They’ve been known to break a thing or two with their O/S updates.
    Bob
    Jul 11, 2012 7:39 AM   in reply to Bob Levine
    I have sent reports on the crashes to Apple as well. But I think when it comes down to it, Apple will say they need to work with us, not we need to make our OS work for Adobe. I have had numerous issues with Apple and print drivers for some of our xerox machines, in the end it comes down to xerox fixing the driver, not Apple.
    Jul 11, 2012 7:57 AM   in reply to wonderings1111
    I disagree with that completely. There is no way an O/S should be upgraded without maintaining some level of compatibility with software that already works on it.
    There have been many cases over the last few years where what appeared to be an Adobe bug was actually and O/S bug. The worst thing Adobe could do is workaround that because there’s no telling what would happen when Apple gets around to fixing it.
    Bob
    Jul 11, 2012 10:04 AM   in reply to kpluck
    15" MBP Retina, and I also have the same issue... anytime indesign wants to 'alert' me. CRASH!
    I really don't want to revert to an older version of the OS, but limited options.
    I'm sure apple will blame adobe, and adobe will blame apple, and the real victim is all of us.
    Jul 18, 2012 10:49 AM   in reply to kpluck
    I'm having this same problem with a new Macbook Pro 13" (non retina) in CS 5.5!
    Jul 18, 2012 4:15 PM   in reply to yableka
    Jul 18, 2012 9:45 PM   in reply to Peter Spier
    Wow! Worked like a charm. Thank you, Peter!
    Jul 19, 2012 12:26 PM   in reply to yableka
    Yes, I saw the same thing when doing any book operations and a dialog box would be displayed (like Synching Cross-References), the outline of the alert box would be displayed then <bam>. Gone. My environment?
    InDesign CS6
    MacBook Pro Retina (2012)
    OS X Lion 10.7.4
    And Peter's link to a patch program worked!!!
    However, I have not seen that on my iMac 27" 2011 edition running the InDesign CS6 on the same Lion. I'm not sure why... Anybody know? Is it just 10.7.4 or a combination on the Retina?
    Aug 25, 2012 2:26 AM   in reply to Peter Spier
    Fantastic: Thank you Peter!
    Estelle
    Dec 3, 2012 5:01 PM   in reply to Peter Spier
    Step two worked from me on the link. Dude, this has been soooooo irritating and finaly something worked.
    Jan 25, 2013 7:49 AM   in reply to kpluck
    I have had the same problem with InDesign CS6, but when running Windows 7 64-bit.  I'm completely patched on both the OS and ID.  Everytime I try to delete a page in my current document, the program crashes.  The possible cause I found was that if subsequent pages had locked items, the page deletion caused the program to crash.  If I unlocked every locked object on the subsequent pages, the page deletion worked fine.
