NickelBuckle9
How to obtain instance name of Movie Clip?
Jul 18, 2012 10:54 AM
Tags: #as3 #array #variable #movie #clip #mc
Hello!
Is there a way to get the instance name of a move clip once it's on the stage?  In my dress up game, I need to know which items are on the doll in order to keep them visible.  My drag and drop feature uses an array and currentTarget:
var dragArray:Array = [Doll.Drawers.Dress1, Doll.Drawers.Dress2, Doll.Drawers.Dress3, Doll.Drawers.Dress4];
          for(var i:int = 0; i < dragArray.length; i++)
                    dragArray[i].buttonMode = true;
                    dragArray[i].addEventListener(MouseEvent.MOUSE_DOWN, item_onMouseDown);
                    dragArray[i].addEventListener(MouseEvent.MOUSE_UP, item_onMouseUp);
function item_onMouseDown(event:MouseEvent):void
               var clip:MovieClip = MovieClip(event.currentTarget);
               clip.startDrag();
function item_onMouseUp(event:MouseEvent):void
               clip.stopDrag();
               if(clip.hitTestObject(Doll.Skins))
                             //Here's where the problem starts!   ----------------------------------------------  //
                              trace("It's on the doll!");
It can successfully run this code.  However, instead of tracing "It's on the doll!", I'd like to turn the currentTarget into it's instance name, which should be "Doll.Drawers.Dress1" etc... and then store that name in an array.
How would I do this?
I've looked into e.target.name, but I keep getting errors...
    Jul 18, 2012 11:03 AM   in reply to NickelBuckle9
         event.target.name
    only if you asign the instance name from the properties panel
    if you create the object with code you nedd asigna a name:
         clip.name="theName"
  • kglad
    Jul 21, 2002
    use the name property of clip (if that's the movieclip whose name you want):
                   clip.startDrag();
                   clip.stopDrag();
                                  trace(clip.name);  // but that won't be Doll.Drawers.Dress1.  it might be Dress1.
  • kglad
    Jul 21, 2002
    Jul 18, 2012 11:45 AM   in reply to NickelBuckle9
    you're welcome.
    p.s.  please mark esdebon's answer as helpful.
  • kglad
    Jul 21, 2002
    Jul 18, 2012 12:40 PM   in reply to NickelBuckle9
    thank you!
