Whitebalance difference camera / Lightroom
Jul 14, 2012 8:21 AM
Tags: #white_balance
I am an underwater photographer and white balance is an important issue. I was advised to set the white balance in my camera (Nikon D90) to  the color temp of my strobes ( 4800 K) so my subject lighted by by strobes would have the correct color. When I import the RAW (NEF) file into lightroom I would expect that the color temp shown in develop mode would be 4800 K.
Unfortunately it is not. It even differs from picture to picture. I would like to know why and if something can be done about this?
    Jul 14, 2012 8:47 AM   in reply to Buitenzorg04
    The color temperature displayed in LR and ACR is affected by how the colors are changed by a particular camera profile so is likely to be a little different than the camera’s computation and a little different if you change camera profiles in Adobe products
    I wouldn’t expect the As Shot numbers to change if the camera profile and in-camera number are the same as long as the in-camera settings didn’t change something else about toning or color in the camera that might make the camera change its numbers slightly.
    I know Canon shoe-mounted flashes can change the camera’s reported auto-WB color-temperature slightly based on whether they are 100% charge or not, but you’re using a custom-WB so that doesn’t fit.
  • Andrew Rodney
    Apr 16, 2009
    Jul 16, 2012 6:35 AM   in reply to Buitenzorg04
    The other item to keep in mind is that anytime you are given a Kelvin value, especially to target (my stobes are 4800K), keep in mind this is a range of colors. Your Mileage Will Vary. One raw converter specifying 4800K can produce a WB that looks quite different (in a magenta/green axis) to another converter with the identical value. Produce WB that looks good to you and don’t get too caught up in the numbers.
  • Christophe CUSSAT BLANC
    Aug 29, 2006
    Jul 16, 2012 8:59 AM   in reply to Buitenzorg04
      The best way to have a "perfect" WB is to shoot a neutral gray surface (like kodak gray cards) and to use the LR color picker to get your wb adjustement. I don't know how to do that underwater but I suppose you can take a photo of any waterproof gray card with your strobes at the begening of your dive session and then synchronize all you set with the color adjustement you have mesured on the first image.
  • Andrew Rodney
    Apr 16, 2009
    Jul 16, 2012 11:53 AM   in reply to Buitenzorg04
    For White Balancing, especially for raw data, a neutral white is better than gray. This target is very neutral and water proof!
    http://www.babelcolor.com/main_level/White_Target.htm
    Jul 16, 2012 12:19 PM   in reply to Andrew Rodney
    Oops:
    "MPORTANT: Sales of TARGETS are suspended until further notice. We are sorry for any disagreement this may cause."
  • Andrew Rodney
    Apr 16, 2009
    Jul 16, 2012 2:05 PM   in reply to Bob_Peters
    Bummer. Best target out there. I emailed them to see what’s up.
    Jul 17, 2012 1:15 PM   in reply to Andrew Rodney
    The Babel white target has a nearly 100% Lambertian reflectivity, which makes it very useful for calibrating spectrophotometers and other instruments where 100% is desirable, but this is not necessarily good for white balancing photographs. A sheet of white paper and most other non-specular objects in a photograph reflect at most only about 90% of the incident light. If one exposes to the right, the 100% target is susceptable to overexposure and being blown in the raw file and a good white balance can not be obtained with blown channels. ACR and Lightroom won't even allow it.
    An spectrally neutral 18% gray card can produce good results, but a higher reflectance will give a better signal to noise ratio and a thoretically better white balance reading. However, with the excellent performance of current sensors, 18% works quite well. A somewhat higher reflectance as with a WhiBal is a good compromise. This is consistent with recommendations to take the white balance from the second brightest patch of a color checker.
  • Andrew Rodney
    Apr 16, 2009
    Jul 17, 2012 2:14 PM   in reply to Bill_Janes
    Did a superb job WB for me (cause it is so darn neutral). It was also awesome for ETTR testing.
    You can use gray cards but for raw workflows, due to the Distribution of data, white is preferred and recommended (and hence the name of the operation). IF the gray card is spectrally neutral, it can work too but if off a bit, you can end up with some color shifts. But there are all kinds of tools out there that can work. I’ve heard of folks getting good results using coffee filters!
    Jul 18, 2012 5:23 AM   in reply to Andrew Rodney
    Actually, white is not preferred in most cases since it is very difficult to produce a spectrally neutral white. The Babel target is one of the few neutral white targets, but it is no longer available. The white patch of the x-rite color checker is not neutral. According to Bruce Lindbloom's measurements, it has L*a*b values of 95.37, -0.73 and +2.5. The neutral 8 patch (adjacent to the white patch) has values of 80.99, -0.039 and +0.21 making it the preferred patch for white balancing because it is not only more neutral, but is less likely to be clipped from inadvertent overexposure.
    BTW, how is the Babel target useful for ETTR?
  • Andrew Rodney
    Apr 16, 2009
    Jul 18, 2012 6:35 AM   in reply to Bill_Janes
    Bill, really. You just want to start another argument?
    Yes it is difficult to produce a spectrally neutral white. Danny did a superb job with his target. Shame it will no longer be offered, glad I have two. Yes, a spectrally neutral white, or gray is harder to produce than a non spectrally neutral white or gray. What’s your point about it not being preferable as I pointed out? That the white patch of the Color Checker is not neutral isn’t desirable is it? I’ve measured it and Danny’s target. One is super darn neutral. What is the argument on your part that this isn’t ideal? Hard to produce, yes, we agree.
    If you’re saying, if you have two patches, one neutral and one not neutral but closer to white, use the more neutral patch, well I don’t think anyone would disagree. I’m saying a white that is neutral is preferable to a gray when both are neutral. And naturally a neutral white is vastly superior for the job than a gray that isn’t neutral.
    Aug 29, 2006
    Jul 18, 2012 6:47 AM   in reply to Buitenzorg04
    I use to say that gray patch is better than white patch for mesuring the temperature (but not 15% neutral gray, it's too dark and there's a chance to have noise in it). I think the real argument for the gray patch is that if you want to expose your photos a bit more, you have the risque to saturate some channels and to loose the information you need : color temperature.
    Jul 18, 2012 7:26 AM   in reply to Andrew Rodney
    Andrew,
    I am not trying to start another argument, but simply want to point out a limitation of the Babel target that you have not acknowledged. There are two ways to use a WB target. One is to take a custom WB in the camera by exposing the target so that it fills the frame of the camera and taking a shot to set the white balance. In this case, white is not necessary since more exposure of a spectrally neutral gray target will give the same results. Most Nikons automatically increase the exposure over mid gray to get a better reading. This method is not practical with the Babel target, since it is so small.
    The other method is to include the target in the scene and then white balance with the eyedropper. If you are exposing to the right a scene that does not contain areas of 100% reflectance (and few do), you place the brightest area of the scene just short of clipping. A sheet of white paper and most naturally occurring whites have about 90% reflectance. If you place these "whites" just short of clipping, the Babel target will be clipped. In this case, it is better to use a WB target that has less reflectance than the brightest area of the scene. Light gray will avoid clipping and still give a low noise reading. The WhiBal is a good compromise and comes in sizes that enable the first WB method.
  • Andrew Rodney
    Apr 16, 2009
    Jul 18, 2012 7:36 AM   in reply to Bill_Janes
    For the custom WB the camera uses for JPEG (that isn’t used for raw)? The Babel target would not be used for this, wasn’t designed for it and is (was) far too expensive for JPEG only users.
    OK, this is the kind of WB I’m talking about. WB using the eyedropper IN the raw converter on a target that is spectrally neutral. I thought I made that clear, if not, sorry. And I’d suggest that the Bable target is a great product to use to avoid clipping (don’t clip it). It is just shy of what one would target as a specular you might want to clip.
    WhiBal is an excellent product. It doesn’t measure out to the neutrality or reflectance of the Babel target but just because Babel has better spec’s (at a price) doesn’t mean WhiBal will not do the job. Had I known when I first posted about Babel that it was not available, well I would not have mentioned it and would have recommend WhiBal. But if price wasn’t an object, and someone asked “based on empirical testing, which target produces the best measurements” I’d have said Babel. The values Danny mentions on his site and what I measured with an EyeOne were extremely close.
    Jul 18, 2012 1:02 PM   in reply to Andrew Rodney
    The first method is the only one to use for in camera JPEGs, but it also works for raw. The preset is white balance is included in the metadata for the raw file. If it is not clipped, the Bable would be the best solution, but if one is ETTRing a black cat a darker target would likely be better.
