AIR-Chayah
Problem applying conditional build tag to more than one folder
Jul 18, 2012 1:14 PM
I applied a conditional build tag to a folder in the HTML Files tree. Success.
Then I tried applying a tag to a different folder. I said yes to checking out the files, but nothing happened. I can't seem to apply a tag to more than one folder in the tree.
My project has five outputs. Four of the outputs are for licensable modules. We don't want the users of licensed modules to see Help topics for modules that they have not licensed. This means that we also need to make sure that only users of licensed modules get to see the Help topics for those modules.
Therefore, based on a reply about how to exclude topics from search results, I am trying to conditionalize the folders, in the Project Manager tree and set the output properties to exclude all topics except those that belong to the output.
For example, I have a Hazard module and a Hazard output. I want to use a build expression such as "NOT Main" so that I can exclude all Main topics from the Hazard output. But I can't do this when RoboHelp won't apply the Main tag to anything.
I know that this will be a good approach when it works. I set up the "Main" output to exclude Hazard topics and none of them showed up.
All help much appreciated.
Carol
    Jul 18, 2012 1:30 PM   in reply to AIR-Chayah
    Sounds like you've got source control in play here - you want to make sure that you've first checked out the entire project to your c:\projects folder before trying to work on applying CBTs to any folders.
    Jul 18, 2012 1:32 PM   in reply to AIR-Chayah
    In a project without source control I was able to apply tags to a parent folder and sub folders quite independently without any problem.
    My own way of working would be to apply a tag called Hazard and exclude that from builds not requiring those topics.
    There is an argument for supplying the help for all modules as they will not have the functionality but might want to buy it when they see what it does. Of course, there can be valid reasons against doing that but it is worth thinking about.
    @petergrainge
    Jul 18, 2012 4:22 PM   in reply to AIR-Chayah
    Hi there
    My spidey sense is tingling and telling me that maybe you are thinking of folders and conditional tagging incorrectly.
    When tagging a folder, it's a *SINGLE SHOT* that says "apply this tag to all topics inside this folder."
    Often, folks will misunderstand this and think they are somehow configuring a situation whereby anything they later place inside the folder is tagged. But that's not the case. If you later add content to the folder you will need to tag it.
    Cheers... Rick
    Helpful and Handy Links
    RoboHelp Wish Form/Bug Reporting Form
    Begin learning RoboHelp HTML 7, 8 or 9 within the day!
    Adobe Certified RoboHelp HTML Training
    SorcerStone Blog
    RoboHelp eBooks
    Jul 19, 2012 12:10 AM   in reply to AIR-Chayah
    Carol
    I misread how you are using the tags.
    @petergrainge
