Is there is any automated way to make fraction.
Jul 17, 2012 4:54 AM
Hi all,
We just got a project which has lots of (1/2, 1/20, 1/300) etc.., the requirement is to change it to fraction.
Any script is available to convert 1/2 to Division/Fraction.
Shaji
    Jul 17, 2012 9:32 AM   in reply to M V SHAJI
    Hi Shaji,
    I am a fresher  in script. But i try to give idea.
    Can you know how many elements will come like (1/2, 1/20, 1/300, 1/4, 1/8 etc..)
    If you know means:
    1. using Glyps  findout all the occurences
    2. Put all your output requirement Division/Fraction for 1/2, 1/20 etc fix in the library elements (i think its around 10 occurences only)
    I hope below script will help you. I didn't check it. Can you edit depends upon your requirement.
    var myDoc = app.documents[0];
    var myLib = app.libraries[0];
    app.findGlypsPreferences = NothingEnum.nothing;
    app.changeGlypsPreferences = NothingEnum.nothing;
    app.findTextPreferences.findGlyps = "1/2 or give unicode value";
    app.changeTextPreferences.changeTo = "";
    anchoricons("1/2 lib name", "1/2 obj style");
    app.documents.item(0).changeText();
    function anchoricons(libName, objStyle)
        myFind = myDoc.findText(true);
        var myCount=0;
        for (i=0; i<myFind.length; i++)
            myText = myLib.assets.item (libName).placeAsset (myFind[i].insertionPoints[-1])[0];
            myText.appliedObjectStyle = myDoc.objectStyles.item (objStyle);
            myCount++;
    3. its same like find and replace
    Can you check it shaaji?
    Learner_X
  • Techi Panda
    Apr 5, 2009
    Jul 18, 2012 5:57 AM   in reply to M V SHAJI
    Jul 18, 2012 2:34 PM   in reply to M V SHAJI
    Maybe you should first explain how you are making these nut fractions manually (as they are commonly known). Then someone might be able to help you automate it.
    Jul 19, 2012 5:36 AM   in reply to M V SHAJI
    this is a roughly approach scripting what you do manually.
    table-, cell-, and objectstyles must exist! tables aren't allowed to have left or right strokes.
    First a Grep-Search for 'Number(s) + Slash + Number(s)' is startet.
    ->anchored Textframe is inserted at insertionpoint 0 of searchresult (the objectstyle is mostly for applying your anchored settings)
    -> searchresult moved into tf
    ->converted to table
    This works in my little test, but there'll be plenty of circumstances it'll won't work as inspected  ...
    Happy testing ;-)
    var theDoc = app.activeDocument;
    var myTableStyle = "tableStyle"; //MUST  be set!!
    var myCellStyle = "cellStyle"//MUST  be set!!
    var myObjectStyle = "objectStyle"//MUST  be set!!
    app.findGrepPreferences = null;
    app.findGrepPreferences.findWhat = "\\d+/\\d+";   //should find all occurrences of number(s) + / + numbers(s)
    var searchResults = theDoc.findGrep();
    for(var i = searchResults.length -1; i >= 0; i--)
    var foundFraction = searchResults[i];
    var newTextFrame = foundFraction.insertionPoints[0].textFrames.add({geometricBounds: [0,0,foundFraction.leading, foundFraction.parentTextFrames[0].geometricBounds[3] - foundFraction.parentTextFrames[0].geometricBounds[1]], appliedObjectStyle:theDoc.objectStyles.itemByName(myObjectStyle)});
    var tmpDest = foundFraction.move(LocationOptions.AT_BEGINNING, newTextFrame);
    var fractionTable= tmpDest.convertToTable('\r', '/', 1);
    fractionTable.appliedTableStyle = "tableStyle"
    setTableWidth(fractionTable);
    newTextFrame.fit(FitOptions.FRAME_TO_CONTENT);
    function setTableWidth(fractionTable){
        var widthArray = [];
            var allCells = fractionTable.cells;
       for(var c = 0; c < fractionTable.cells.length; c++){
            var aCell = fractionTable.cells[c];
                    aCell.appliedCellStyle = "cellStyle"
    widthArray.push((aCell.texts[0].endHorizontalOffset - aCell.texts[0].horizontalOffset) + aCell.leftInset + aCell.rightInset)
    widthArray.sort(Numsort);
    fractionTable.width = widthArray[widthArray.length-1]
    function Numsort(a,b){return a - b}
    Jul 19, 2012 6:41 AM   in reply to M V SHAJI
    It's easy to script
    one needs to set up 3 object styles
    two for text frames that will include the top (23) and bottom (57) numbers and one for the middle line
    insert as an inline anchored object at the insertion point a text frame, for simplicity I'll call this the main text frame.
    In the main text frame insert the top and bottom number text frames and the line, i.e. 3 custom anchored objects.
    The top and bottom text frames should to the anchored setting like this
    and
    For the line object style set both the reference point to the middle
    Make sure to set up the paragraph styles properly
    All this can be done without scripting one setup you can just copy and paste the main text frame and change the numbers as needed.
    Of course scripting it with a keyboard shortcut would be much easier for you.
    Best to have 2 scripts 1 for inserting the main text frame so you can enter the numbers and another for after you have entered the number to adjust the geometricBounds (dimensions in this case) of the line top, bottom and main text frames according to the width of the numbers you entered.
    Trevor
    Note: in the top screenshot I was not careful on the size of the top and bottom text frames so the line comes to close to the 57. With a bit of care it would look good.
    Message was edited by: ~ Trevor ~
    Jul 19, 2012 6:47 AM   in reply to -hans-
    Just wanted to add that I didn't see Hans script when I posted my above post.
    Not that it makes a difference.
    Trevor
