msgreenmnm
Approval Signature
Jul 18, 2012 11:26 AM
I need help figuring out how I can email a PDF fillable form to someone and they only have access to approve the form with their signature and no other editing rights?
I also work at a college and this would be an Educational Plan the advisors will fill out and email to the students so not sure if it would only work if the recipients have a certain Adobe? Any help would be much appreciated.
April
    Jul 18, 2012 11:37 AM   in reply to msgreenmnm
    The short answer is click Help, read, and then ask questions about what is not clear.
    The overview is there are several ways to do it: you can require the first sig to be a certification sig which locks the doc, or on signing the user can  choose to lock the doc, or . . . .
    Any version of Acrobat or Reader (if the document is Rights Enabled) will work.
    Ben
    Jul 18, 2012 2:29 PM   in reply to msgreenmnm
    Sig fields are form fields, so if signing is allowed then form field fill in is allowed.
    So,
    • If you are certifying, allow form fill in and sigs only, and then go to each field and lock the field (but what is the point of having the field?)
    • If you use a regular (approval) sig, check the "Lock Doc" checkbox.
    I'm sure there are other more sophisticated methods you can use, but I don't know them off the top of my head.
    Ben
    Jul 18, 2012 2:43 PM   in reply to msgreenmnm
    What I see with 10.1.3.
    Jul 18, 2012 2:58 PM   in reply to msgreenmnm
    What version are you using?
    Jul 18, 2012 3:18 PM   in reply to msgreenmnm
    The "Lock Doc" checkbox only appears when signing the last unsigned field. Try out your method above.
    Ben
