Is it best to uninstall CS4 Production Premium before I install CS6 from disk?
If I remove CS4 from my PC and install CS6 on my PC - can I put CS4 on my laptop legally?
Thanks.
What kind of problems are you talking about here?
I just installed CS6, but didn't uninstall CS4 first. Sounds like unless I'm dying for space (which I kind of am), I should not uninstall CS4 or there will be problems.
What do I need to do? Is there a best way to uninstall? I've read about Cleanups or Cleansweeps or some such thing, can you give me the specific steps that I need to follow? CS6 opens just fine right now!
SunnyDulce you will want to utilize the uninstaller to remove the software. I am unsure which operating system you are using but if it is Windows then you would use Programs & Features to remove the software. The issue you may run into, which I believe Mylenium is referring too, is that you will need to manually set your file associations to the CS6 applications after you remove CS4.
