how can i accentuate whites and blacks in photoshop b/w ,no acr?
Jul 17, 2012 11:02 PM
Hi
how can i accentuate whites and blacks in photoshop in black and white photos?
i tried silver evef 2 and there is a feature to boost whites and blacks http://www.niksoftware.com/silverefexpro/usa/entry.php?view=usa/featur es.html#amplify_blacks_and_whiteshttp://
levels and curves don't give me the same results
i tried to create a luminocity mask of whites with selective color
is there a great skill to boost whites for example?
thanks
cheers
    Jul 17, 2012 11:29 PM   in reply to mantralightroom
    Perhaps you'd like to post two samples of the same image, one completed in Silver Efex and the other just in Photoshop so we can see the difference you see?
    The image below was converted to B&W, tinted, and had some of the edges darkened in Silver Efex, but the final Black/White levels were adjusted with a Levels Adjustment Layer in Photoshop.
    I think Silver Efex is fantastic, but I tend to stay away from the presets unless I want a particularly "stylized" look.
    Good luck
    Paul
    Jul 18, 2012 12:41 AM   in reply to mantralightroom
    Like pf22 said, examples of what you have and want to achieve might make it easier to assess what alternative procedures seem feasible.
    Jul 18, 2012 1:08 AM   in reply to c.pfaffenbichler
    "Create a luminosity mask with selective color"?
    The best way to create a 'luminosity mask' would be to go into your channels panel and ctrl+click the RGB channel, this will select the darker levels in the image. With the selection you can now add an adjustment layer, If you need to work on the highlights, do the same thing with an inverted selection/mask.
    Silver Efex outputs nice images, but I find it just amazingly sluggish, even on a speedy setup, compared to other bw filters if thats what you want to use. For bw filters you should also check out the good old alien skin exposure filter set, blazingly fast compared to niksoft.
    Jul 18, 2012 2:23 AM   in reply to dutotone
    The appropriate Blend If > Underlying Layer-settings should achieve something similar – not identical, though.
    Jul 18, 2012 10:12 AM   in reply to mantralightroom
    Is it a kind of High Key effect that you are after? You can achieve that with playing around with duplicating the layer, blur it and blend it onto the original one as soft light or maybe even overlay.
    Jul 18, 2012 5:06 PM   in reply to dutotone
    Do it in Camera RAW. Or Topaz.
    Jul 18, 2012 8:56 PM   in reply to mantralightroom
    mantralightroom wrote:
    because silvers v2 is a nice plugin , i like  how it can boost ,aplify the whites and the blacks
    can't do the same results with levels or curve or selective color
    I use CS5 with Silver Efex Pro v2, but again, without seeing an example of what you're seeing or what you want to achieve, it's difficult to suggest what specific technique will get you what you want using Photoshop alone.
    I'm sure some combination of Luminosity Mask, Levels/Curves/Contrast Adjustment Layers would probably give you what you want, but if the Silver Efex Presets, perhaps with some tweaking/customization, give you what you want, and the speed, or lack thereof, is not a problem, well, just stick with what you have!
    And as Duotone and Lundberg have pointed out, there are alternatives to Siver Efex; I'm sure you could download a 30 day trial of those packages to play with and see if they meet your needs.
    Good luck
    Paul
