I installed ColdFusion10 Developer on my Win7 desktop with IIS7.5 but when I go to localhost/xxx.cfm a popup dialogue box opens >> Opening .cfm file...You have chosen to open index.cfm which is a cfm file from http://localhost...What should Firefox do with this file? (Open with-browse/FlashGot/Save File)<<<
Why is IIS7.5 not serving .cfm in localhost normally? Grateful for help to fix this (see my post on StackOverflow on this:http://stackoverflow.com/questions/11467168/coldfusion10-developer-and -windows7-iis7-5 )
EDIT I am grateful for help with this please (it is driving me nuts..)! I have no handler mappings for .cfm-how do I manually add these to my IIS7.5 for my ColdFusion10 developer install? I need to find the directory to map to the correct .dll file for .cfm etc? Am I correct?-I cannot find any info on Google about this for CF10 developer edn (there are several links to CF7/8 which have given me a general idea but I need a specific fix....)
Thanks for your reply.
Sure html pages work fine. I have run CF10 web config tool but no help.
Is IIS configured?-well that is the crucial question...as I state there are no handler mappings for .cfm
but IIS has ISAPI and CGI enabled.
Can anyone please tell me how to add cfm handler mappings manually for CF10 Dev ?
Most grateful for further help please...:-)
Thanks -I attach screenshots of my cf10 config tool...
obviously not like your image/config tool.
It is a bit hard to see from the second image but I have no ability to add a webserver & the configuration directory is greyed out/inactive.
Here is my web-config file:
<?xml version="1.0" encoding="UTF-8"?>
<configuration>
<system.webServer>
<handlers accessPolicy="Read, Execute, Script" />
<directoryBrowse enabled="false" />
<defaultDocument>
<files>
<clear />
<add value="Default.asp" />
</files>
</defaultDocument>
<httpErrors>
<clear />
</httpErrors>
<staticContent>
<mimeMap fileExtension=".cfm" mimeType="application/x-coldfusion" />
</staticContent>
</system.webServer>
</configuration>
What this means I do not know-is it right or wrong & how to fix if wrong!?
Hi again
I forgot to say that nothing changes if I check 32 bit webserver box either!
I still cannot add a webserver and the configuration directory box remains greyed out/inactive.
All this is very frustrating. I have posted for help with this on IIS forums but no successful help yet...
On Saturday I tested this on my mothers computer (Win7 desktop-& same Advent model as mine) & ColdFusion worked fine with IIS.
(The first time IIS was enabled on her computer-she very rarely uses her computer...).
I have installed lots of software on my Win7 desktop and possibly have some conflicting Windows versions causing issues (eg my network diagnostics policy service will not start and I cannot fix this. I am tempted to remove all Win programs and start from scratch but am very daunted at the prospect of this!).
I still do not have .cfm enabled/present in handler mappings-does anyone know how I can manually add this?
I remain grateful for further advice on how I can fix ColdFusion in IIS.
I look forward to more helpful replies-thanks
My Win7 & CF10 are both 64 bit versions. However I have set default app pool to true to enable 32 bit apps.
Is this right?
This is very strange and very frustrating why it refuses to work on my computer!
I attach another screenshot from running wsconfig tool:
I still do not have IIS def website handler mappings for .cfm but I do have .cfm in IIS def website Mime types (entry type is local-not inherited as other entries).
I have followed these instructions from http://help.adobe.com/en_US/ColdFusion/10.0/Installing/WSc3ff6d0ea7785 9461172e0811cdec18a15-7ffb.html
but with no success!
Note: The server or cluster does not have to reside on the web server computer.
In the Web Server Properties area, select IIS and specify the website. For IIS, you typically specify All.
Configuring IIS:
What is the wrong with my IIS/ColdFusion install?! How can I fix it?!.........help........:-(
I am still unable to configure ColdFusion in IIS on my Win7 machine.
I tried reinistalling several times and as administrator. The same problems I have detailed in my posts here remain.
I want to enable cf in IIS on my computer. Can anyone please help me do this?
I look forward to helpful replies-many thanks
Today I thought I might make some progress with this when I found more info on configuring CF & IIS manually at this link:
http://helpx.adobe.com/coldfusion/kb/coldfusion10-iis-manual-connector -configuration.html
After quite sometime following these instructions to configure this setup (& I finally found how to add cf handlers also with some help from this link re adding handlers:
http://www.adobe.com/devnet/coldfusion/articles/iis-configuration.html), I did not succeed but went from Http 403 error to Http 404.17 error and am stuck now trying to fix that!
Interestingly (but unhelpfully) I have found if I run cf wsconfig tool along the way it still doesn't work & it then screws up my config/wsconfig/1 folder (ie this folder I manually create & it vanishes/gets deleted after running the tool! Not very helpful as I then have to recreate it & it's contents again-very time consuming!).
In regards to 404.17 error I have seen various reports of this & various methods proposed to solve/fix it (includes set app pool to Asp.Net v4 /enable Net Communication http/set app pool to 32bit but none has worked so far).
This is being seriously troublesome to get CF10 dev & my IIS to work together on my Win7 computer! I continue to try to fix it & live in hope that one day I will succeed & then I can start to learn & use ColdFusion...
Meantime any more help is gratefully appreciated, many thanks
Any updates? I'm running into the same problem trying to load CF10 to a Win2008 R2 machine. This is a total fresh CF10 install on a fresh Win/IIS7 install. Immediately after CF10 is installed I click to run CFAdmin and get this:
I have tried many things: re-installing CF, messing with 32/64 bit versions, etc, wsconfig tool, etc. No matter what I try I always end up back at 500 error. WTF is going on. Been working with CF since 4.5 and never had this kind of issue.
<defaultDocument><files><clear /><add value="Default.asp" /></files></defaultDocument>
Hi richard350,
Regarding inability to add configuration, please ensure all of these IIS features are enabled:
- ASP.NET
- CGI
- ISAPI Extensions
- ISAPI Filters
Regarding that web.config file, it will esssentially clear the Default Document list (this list will be created when the configuration is added) and only permit Default.asp as a Default Document. Just disable the web.config file by renaming it to "web.config_old". Then restart IIS.
Regardless of clean CF/Windows install, if the site itself existed within a CF9 install then there can be an issue w/ the web.config file in the site's root. Going forward, this issue has been fixed. And CF10 CF sites will run w/o issue in CF11. Additionally, CF10 and CF11 will even run side-by-side successfully with the same IIS7+ sites defined in each.
-Aaron
Hi itisdesign
I have all items configured in IIS
My current web-cofig:
<configuration>
<system.webServer>
<defaultDocument>
<files>
<clear />
<add value="index.php" />
<add value="Default.htm" />
<add value="Default.cfm" />
<add value="index.htm" />
<add value="index.html" />
<add value="iisstart.htm" />
<add value="default.aspx" />
</files>
</defaultDocument>
<handlers>
<clear />
<add name="php-5.3.6" path="*.php" verb="GET,HEAD,POST" modules="FastCgiModule" scriptProcessor="C:\Program Files (x86)\PHP\php-cgi.exe" resourceType="Either" requireAccess="Script" />
<add name="hbmxmlHandler" path="*.hbmxml" verb="*" modules="IsapiModule" scriptProcessor="C:\ColdFusion10\config\wsconfig\1\isapi_redirect.dll " resourceType="Unspecified" preCondition="bitness64" />
<add name="cfswfHandler" path="*.cfswf" verb="*" modules="IsapiModule" scriptProcessor="C:\ColdFusion10\config\wsconfig\1\isapi_redirect.dll " resourceType="Unspecified" requireAccess="Script" preCondition="bitness64" />
<add name="cfrHandler" path="*.cfr" verb="*" modules="IsapiModule" scriptProcessor="C:\ColdFusion10\config\wsconfig\1\isapi_redirect.dll " resourceType="Unspecified" requireAccess="Script" preCondition="bitness64" />
<add name="cfmlHandler" path="*.cfml" verb="*" modules="IsapiModule" scriptProcessor="C:\ColdFusion10\config\wsconfig\1\isapi_redirect.dll " resourceType="Unspecified" requireAccess="Script" preCondition="bitness64" />
<add name="cfmHandler" path="*.cfm" verb="*" modules="IsapiModule" scriptProcessor="C:\ColdFusion10\config\wsconfig\1\isapi_redirect.dll " resourceType="Unspecified" requireAccess="Script" preCondition="bitness64" />
<add name="cfcHandler" path="*.cfc" verb="*" modules="IsapiModule" scriptProcessor="C:\ColdFusion10\config\wsconfig\1\isapi_redirect.dll " resourceType="Unspecified" requireAccess="Script" preCondition="bitness64" />
<add name="rules-Integrated" path="*.rules" verb="*" type="System.ServiceModel.Activation.HttpHandler, System.ServiceModel, Version=3.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" preCondition="integratedMode" />
<add name="rules-ISAPI-2.0" path="*.rules" verb="*" modules="IsapiModule" scriptProcessor="C:\Windows\Microsoft.NET\Framework\v2.0.50727\aspnet _isapi.dll" preCondition="classicMode,runtimeVersionv2.0,bitness32" />
<add name="rules-64-ISAPI-2.0" path="*.rules" verb="*" modules="IsapiModule" scriptProcessor="C:\Windows\Microsoft.NET\Framework64\v2.0.50727\aspn et_isapi.dll" preCondition="classicMode,runtimeVersionv2.0,bitness64" />
<add name="xoml-Integrated" path="*.xoml" verb="*" type="System.ServiceModel.Activation.HttpHandler, System.ServiceModel, Version=3.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" preCondition="integratedMode" />
<add name="xoml-ISAPI-2.0" path="*.xoml" verb="*" modules="IsapiModule" scriptProcessor="C:\Windows\Microsoft.NET\Framework\v2.0.50727\aspnet _isapi.dll" preCondition="classicMode,runtimeVersionv2.0,bitness32" />
<add name="xoml-64-ISAPI-2.0" path="*.xoml" verb="*" modules="IsapiModule" scriptProcessor="C:\Windows\Microsoft.NET\Framework64\v2.0.50727\aspn et_isapi.dll" preCondition="classicMode,runtimeVersionv2.0,bitness64" />
<add name="svc-ISAPI-2.0-64" path="*.svc" verb="*" modules="IsapiModule" scriptProcessor="%SystemRoot%\Microsoft.NET\Framework64\v2.0.50727\as pnet_isapi.dll" preCondition="classicMode,runtimeVersionv2.0,bitness64" />
<add name="svc-ISAPI-2.0" path="*.svc" verb="*" modules="IsapiModule" scriptProcessor="%SystemRoot%\Microsoft.NET\Framework\v2.0.50727\aspn et_isapi.dll" preCondition="classicMode,runtimeVersionv2.0,bitness32" />
<add name="svc-Integrated" path="*.svc" verb="*" type="System.ServiceModel.Activation.HttpHandler, System.ServiceModel, Version=3.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" preCondition="integratedMode" />
<add name="WebDAV" path="*" verb="PROPFIND,PROPPATCH,MKCOL,PUT,COPY,DELETE,MOVE,LOCK,UNLOCK" modules="WebDAVModule" resourceType="Unspecified" requireAccess="None" />
<add name="ASPClassic" path="*.asp" verb="GET,HEAD,POST" modules="IsapiModule" scriptProcessor="%windir%\system32\inetsrv\asp.dll" resourceType="File" />
<add name="SecurityCertificate" path="*.cer" verb="GET,HEAD,POST" modules="IsapiModule" scriptProcessor="%windir%\system32\inetsrv\asp.dll" resourceType="File" />
<add name="ISAPI-dll" path="*.dll" verb="*" modules="IsapiModule" resourceType="File" requireAccess="Execute" allowPathInfo="true" />
<add name="TraceHandler-Integrated" path="trace.axd" verb="GET,HEAD,POST,DEBUG" type="System.Web.Handlers.TraceHandler" preCondition="integratedMode" />
<add name="WebAdminHandler-Integrated" path="WebAdmin.axd" verb="GET,DEBUG" type="System.Web.Handlers.WebAdminHandler" preCondition="integratedMode" />
<add name="AssemblyResourceLoader-Integrated" path="WebResource.axd" verb="GET,DEBUG" type="System.Web.Handlers.AssemblyResourceLoader" preCondition="integratedMode" />
<add name="PageHandlerFactory-Integrated" path="*.aspx" verb="GET,HEAD,POST,DEBUG" type="System.Web.UI.PageHandlerFactory" preCondition="integratedMode" />
<add name="SimpleHandlerFactory-Integrated" path="*.ashx" verb="GET,HEAD,POST,DEBUG" type="System.Web.UI.SimpleHandlerFactory" preCondition="integratedMode" />
<add name="WebServiceHandlerFactory-Integrated" path="*.asmx" verb="GET,HEAD,POST,DEBUG" type="System.Web.Services.Protocols.WebServiceHandlerFactory, System.Web.Services, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" preCondition="integratedMode" />
<add name="HttpRemotingHandlerFactory-rem-Integrated" path="*.rem" verb="GET,HEAD,POST,DEBUG" type="System.Runtime.Remoting.Channels.Http.HttpRemotingHandlerFactor y, System.Runtime.Remoting, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" preCondition="integratedMode" />
<add name="HttpRemotingHandlerFactory-soap-Integrated" path="*.soap" verb="GET,HEAD,POST,DEBUG" type="System.Runtime.Remoting.Channels.Http.HttpRemotingHandlerFactor y, System.Runtime.Remoting, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" preCondition="integratedMode" />
<add name="AXD-ISAPI-2.0" path="*.axd" verb="GET,HEAD,POST,DEBUG" modules="IsapiModule" scriptProcessor="%windir%\Microsoft.NET\Framework\v2.0.50727\aspnet_i sapi.dll" preCondition="classicMode,runtimeVersionv2.0,bitness32" responseBufferLimit="0" />
<add name="PageHandlerFactory-ISAPI-2.0" path="*.aspx" verb="GET,HEAD,POST,DEBUG" modules="IsapiModule" scriptProcessor="%windir%\Microsoft.NET\Framework\v2.0.50727\aspnet_i sapi.dll" preCondition="classicMode,runtimeVersionv2.0,bitness32" responseBufferLimit="0" />
<add name="SimpleHandlerFactory-ISAPI-2.0" path="*.ashx" verb="GET,HEAD,POST,DEBUG" modules="IsapiModule" scriptProcessor="%windir%\Microsoft.NET\Framework\v2.0.50727\aspnet_i sapi.dll" preCondition="classicMode,runtimeVersionv2.0,bitness32" responseBufferLimit="0" />
<add name="WebServiceHandlerFactory-ISAPI-2.0" path="*.asmx" verb="GET,HEAD,POST,DEBUG" modules="IsapiModule" scriptProcessor="%windir%\Microsoft.NET\Framework\v2.0.50727\aspnet_i sapi.dll" preCondition="classicMode,runtimeVersionv2.0,bitness32" responseBufferLimit="0" />
<add name="HttpRemotingHandlerFactory-rem-ISAPI-2.0" path="*.rem" verb="GET,HEAD,POST,DEBUG" modules="IsapiModule" scriptProcessor="%windir%\Microsoft.NET\Framework\v2.0.50727\aspnet_i sapi.dll" preCondition="classicMode,runtimeVersionv2.0,bitness32" responseBufferLimit="0" />
<add name="HttpRemotingHandlerFactory-soap-ISAPI-2.0" path="*.soap" verb="GET,HEAD,POST,DEBUG" modules="IsapiModule" scriptProcessor="%windir%\Microsoft.NET\Framework\v2.0.50727\aspnet_i sapi.dll" preCondition="classicMode,runtimeVersionv2.0,bitness32" responseBufferLimit="0" />
<add name="AXD-ISAPI-2.0-64" path="*.axd" verb="GET,HEAD,POST,DEBUG" modules="IsapiModule" scriptProcessor="%windir%\Microsoft.NET\Framework64\v2.0.50727\aspnet _isapi.dll" preCondition="classicMode,runtimeVersionv2.0,bitness64" responseBufferLimit="0" />
<add name="PageHandlerFactory-ISAPI-2.0-64" path="*.aspx" verb="GET,HEAD,POST,DEBUG" modules="IsapiModule" scriptProcessor="%windir%\Microsoft.NET\Framework64\v2.0.50727\aspnet _isapi.dll" preCondition="classicMode,runtimeVersionv2.0,bitness64" responseBufferLimit="0" />
<add name="SimpleHandlerFactory-ISAPI-2.0-64" path="*.ashx" verb="GET,HEAD,POST,DEBUG" modules="IsapiModule" scriptProcessor="%windir%\Microsoft.NET\Framework64\v2.0.50727\aspnet _isapi.dll" preCondition="classicMode,runtimeVersionv2.0,bitness64" responseBufferLimit="0" />
<add name="WebServiceHandlerFactory-ISAPI-2.0-64" path="*.asmx" verb="GET,HEAD,POST,DEBUG" modules="IsapiModule" scriptProcessor="%windir%\Microsoft.NET\Framework64\v2.0.50727\aspnet _isapi.dll" preCondition="classicMode,runtimeVersionv2.0,bitness64" responseBufferLimit="0" />
<add name="HttpRemotingHandlerFactory-rem-ISAPI-2.0-64" path="*.rem" verb="GET,HEAD,POST,DEBUG" modules="IsapiModule" scriptProcessor="%windir%\Microsoft.NET\Framework64\v2.0.50727\aspnet _isapi.dll" preCondition="classicMode,runtimeVersionv2.0,bitness64" responseBufferLimit="0" />
<add name="HttpRemotingHandlerFactory-soap-ISAPI-2.0-64" path="*.soap" verb="GET,HEAD,POST,DEBUG" modules="IsapiModule" scriptProcessor="%windir%\Microsoft.NET\Framework64\v2.0.50727\aspnet _isapi.dll" preCondition="classicMode,runtimeVersionv2.0,bitness64" responseBufferLimit="0" />
<add name="CGI-exe" path="*.exe" verb="*" modules="CgiModule" resourceType="File" requireAccess="Execute" allowPathInfo="true" />
<add name="SSINC-stm" path="*.stm" verb="GET,POST" modules="ServerSideIncludeModule" resourceType="File" />
<add name="SSINC-shtm" path="*.shtm" verb="GET,POST" modules="ServerSideIncludeModule" resourceType="File" />
<add name="SSINC-shtml" path="*.shtml" verb="GET,POST" modules="ServerSideIncludeModule" resourceType="File" />
<add name="TRACEVerbHandler" path="*" verb="TRACE" modules="ProtocolSupportModule" requireAccess="None" />
<add name="OPTIONSVerbHandler" path="*" verb="OPTIONS" modules="ProtocolSupportModule" requireAccess="None" />
<add name="StaticFile" path="*" verb="*" modules="StaticFileModule,DefaultDocumentModule,DirectoryListingModul e" resourceType="Either" requireAccess="Read" />
</handlers>
</system.webServer>
</configuration>
When I disable this by renaming & then restart IIS I get :
HTTP Error 404.3 - Not Found The page you are requesting cannot be served because of the extension configuration. If the page is a script, add a handler. If the file should be downloaded, add a MIME map.
Any more ideas to help me get CF & my IIS working?
@ sdsinc_pmascari
I'm sorry to hear of your problem with CF10 & IIS, but I do not know what is causing your error or how to fix it.
We both have problems that need fixing!
I too have spent loads of time trying to get it to work on my computer.
All very frustrating and we both still need good help to fix these problems.
Can anyone here help get these problems fixed please?
Hi richard350,
richard350 wrote:
ColdFusion10 Developer on my Win7 desktop with IIS7.5 [...] My Win7 & CF10 are both 64 bit versions.
Same here.
This is False on mine.
I don't even have a web.config file. It isn't needed. It can remain renamed/disabled.
That article no longer applies to ColdFusion as of version 10.
This is a known issue, and a future version of the tool _may_ provide a "Preserve connector settings" checkbox.
The first issue to resolve here is the disabled "IIS Web Site" option in wsconfig.exe (Web Server Configuration Tool). Have you tried reinstalling IIS (basically uncheck the "Internet Information Services" checkbox and after it uninstalls then check the box again and ensure the 4 IIS features required by CF, which I listed in my previous post, are also enabled)? I'd make a backup copy of C:\Windows\System32\inetsrv\config\applicationHost.config before uninstalling IIS, in case you want to restore IIS back to its current settings.
-Aaron
Thanks Aaron
Yes I have on several times uninstalled IIS and reinstalled it and ensured the needed CF IIS options are enabled.
It has made no difference & IIS & CF10 do not work together for me on this computer.
I have sadly almost given up trying to fix this and use CF10 Dev with IIS as I have spent so long trying to get this fixed and I have other regular work to do which suffers because of the time I spend on this. If anyone could give further advice I will retry-thanks
I thought I read somewhere that .Net Extensibility is also required (in addition to the four other Windows features that Aaron mentioned) for the Web Server Configuration Tool to run properly. Also, if the GUI tool isn't working, have you tried the command line version of the tool? See pages 16 & 17 of the Installing ColdFusion 10 document for command line syntax.
HTH,
-Carl V. (@cfvonner on Twitter)
Hello,
If you still are having problems, i outlined the IIS configuration steps in the 2nd part of my blog post here http://thefusionator.com/index.cfm?blogID=2
Initially Had problems installing CF10 64bit dev on Win7 (64bit) with IIS7.5 getting the same http 500 error. Having previously ran CF9 ok
The following worked:
1) Uninstall IIS and restart
2) Rename existing inetpub folder
3) Reinstall IIS With this Note: If you are configuring IIS 7 or IIS 7.5, before you proceed, ensure that you have the options ISAPI Extensions (Internet Information Service > Web Management Tools > World Wide Web Services > Application Development Features), ASP.NET , and CGI selected in the Windows Features dialog box (Start > Control Panel > Programs and Features > Turn Windows features on or off).
4) Install CF10 64 bit
5) CF Admin opened after install OK
Mine was a bit different for the resolution. I found that I had the 32-bit CF 10 installed on my x64 Win 7. I read this article stating that I needed to allow IIS7 to run in 32 bit mode. I ran the command line prompt, immediately CF was working!
Any resolution to this? I'm having the same sort of problem. At first I had Coldufsion 10 developer installed on a Windows 2008 R2 64bit machine and everyting was fine. Then I installed update 4 and I received a "Service unavailable" message. It said I need to re run the web configuration, so I did and when I did I had the same problem, the "Ok" is disabled. I went and reinstalled Coldfusion 10 from scratch and Coldfusion seems to work fine, but no sites show up in the web configuration wizard and the "Ok" is still disabled, so I can't install the patch.
I'm using the default install of 64 bit Coldfusion 10 to IIS 7.5. It just seems as if the 64 bit version of Coldfusion has a lot of issues.
I got it working after a re-install.
The web connector wizard seemed to work when used on a per-IIS-site basis.
The "All" option did nothing.
This was on a DEV machine so it took up time but I wasn't too anxious.
I haven't applied the mandatory update to the server yet out of fear of
breaking the connectors etc etc
Come on Adobe - this is affecting a large number of users!
@Richard350,
I just replied to your SO post. Bottom line, make sure you have the correct IIS components installed before running the Web Server Configuration Tool:
For those who can get "per-site" connectors working but not "All" sites, what account are you logged in as when you run the Web Server Configuration Tool? Does that account have administrative rights on the computer? The "ALL" websites configuration writes changes into the IIS configuration (which requires Administrator privileges) and each site's web.config file (which doesn't necessarily require Administrator privileges), while the "per-site" connectors write changes ONLY to web.config.
-Carl V.
Thanks, but all those components are installed. I have been running the wizard under an administrator account.
The first time I installed Coldfusion 10, everything was fine. It's when I installed update 4 that all the problems started to happen.
The funny thing now is that Coldfusion seems to be working fine, I can access my application and the CF Administrator it's just no sites show in the web configuration wizard and the "Ok" is disabled, even after a reinstall of Coldfusion.
I'm wondering if it's a permission thing on some folders, I've had lots of problems with this on 2008 R2, but why it would stop working now, I don't know unless it's another one of those notorious windows patches.
I ran into some wierd issues with Updater 4 too. I posted on the ColdFusion Server Administration forum with my issues.
-Carl V.
I've just remembered my issue was related to installing CF10 for IIS sites
that had previously been run with CF9
In the end I set up new IIS sites and then ran the connector wizard
site-by-site and finally it worked. Note CF9 was removed before installing
CF10..
I was getting Http Error 500 as well as connector problems. As in
I have the same issue. "All" option does nothing, I can choose the sites one by one with the connector tool and they work fine. The strange thing is that "half" of the site works, but some doesn't. This happened on two different servers, Windows 2k8 r2 Fresh installations. CF8 worked fine for me. Is there any solution to this yet?
I posted this bug on the Adobe Bugbase: https://bugbase.adobe.com/index.cfm?event=bug&id=3364745
We haven't resolved it yet, but I tried running wsconfig through the command line and found that java could not create a file in the executeappcommand folder in the temp space of the current user even though that user was administrator. It gives an access is denied message. We believe McAfee intruision detection may be blocking this action. We are trying to gain access to turn off the McAfee intruision detection and then see if it works.
Always be sure to run wsconfig as an administrator and use the "Run As Administrator" option. If that doesn't work it might be your virus protection/intrusion detection software.
Hi all,
I would like to share some of my experience installing CF10 in my laptop ( Win 7 Ultimate (64-bit) , 4GB RAM ) , IIS Ver 7.5.
I have some hard time.. install, uninstall few times.. hours of browsing looking for solution .. trial n error.
It took me about a week to finally configure it correctly.
IF not mistaken ( IF, i need to stress on this word ), I finally manage to get the configuation done correctly by following the instruction from Adobe website.
Try this link : http://help.adobe.com/en_US/ColdFusion/10.0/Installing/WSc3ff6d0ea7785 9461172e0811cdec18a15-7ffb.html
Oh, I also actually re-format my laptop once before able to get it right.
After days of frustration, finally I manage to get the browser ( IE ) to open .cfm file from my localhost,
with address http://localhost/foldername/file.cfm
Now, another issue arise. I found out that, the it took quite a while to load the .cfm page.
I might say, my laptop required 30 secs - 1 min to load the .cfm page, even just to display simple page with word 'Test' on the .cfm page.
I still wondering what is the main issue here. I suspect , could be the IIS 7.5 setting.
Anyone who has similar issue (slow loading of .cfm page), I love to hear your opinion / suggestion to resolve this issue.
Thanks in advance.
Sorry, I just now saw your question.
What we discovered is when using the Web Config tool never choose "All" for the web sites. Don't know what the issue is but it screws everything up and does not configure anything correctly. We wiped out everything and started over and then when using the web config tool to connect CF to IIS we went site by site and connected each one individually. Worked like a charm after that.
Hope that helps.
I don't know if folks are still having trouble with this, but I'll share my experience and how I got it to work.
Environment: Windows 7 64bit, IIS 7.5, had CF developer 9.02 installed.
After installing, answering to use CF 10 for sites, first problem was that it tried to go to CF admin/config using 127.0.0.1 for localhost. I'm on comcast with wifi, so my localhost is 192.168.0.104.
Changed url to localhost and got error about duplicate entry for hbmxmlHandler. This is in the webroot web.config file, in my case C:\inetpub\wwwroot\
When I looked at web.config, handlers were pointing to CF9 not CF10. Also, in IIS, the virtual directories for CFIDE, Jakarta, etc. were still CF9.
Strangely enough, the CF10 web server configuration tool only had "None" available for sites to configure on localhost!
To eliminate all the trial and error iterations that didn't work... here's what did:
1) Go to the ColdFusion9\runtime\bin folder and execute the wsconfig.exe (right click to run as administrator) to remove the ISS All. So, no CF9 site support on any sites.
2) Run the CF10 web server configuration tool to add ISS All. Do not check 32bit support if you're on 64bit, it won't work.
3) Alter the web.config (for every site) to delete the <handler> and <defaultdocument> sections.
My web.config looked like this:
<configuration>
<system.webServer>
<handlers>
<add name="JWildCardHandler" path="*" verb="*" modules="IsapiModule" scriptProcessor="C:\ColdFusion9\runtime\lib\wsconfig\1\jrun_iis6_wild card.dll" resourceType="Unspecified" requireAccess="None" />
<add name="hbmxmlHandler" path="*.hbmxml" verb="*" modules="IsapiModule" scriptProcessor="C:\ColdFusion9\runtime\lib\wsconfig\jrun_iis6.dll" resourceType="Either" responseBufferLimit="0" />
<add name="cfswfHandler" path="*.cfswf" verb="*" modules="IsapiModule" scriptProcessor="C:\ColdFusion9\runtime\lib\wsconfig\jrun_iis6.dll" resourceType="Either" responseBufferLimit="0" />
<add name="cfrHandler" path="*.cfr" verb="*" modules="IsapiModule" scriptProcessor="C:\ColdFusion9\runtime\lib\wsconfig\jrun_iis6.dll" resourceType="Either" responseBufferLimit="0" />
<add name="cfcHandler" path="*.cfc" verb="*" modules="IsapiModule" scriptProcessor="C:\ColdFusion9\runtime\lib\wsconfig\jrun_iis6.dll" resourceType="Either" responseBufferLimit="0" />
<add name="cfmlHandler" path="*.cfml" verb="*" modules="IsapiModule" scriptProcessor="C:\ColdFusion9\runtime\lib\wsconfig\jrun_iis6.dll" resourceType="Either" responseBufferLimit="0" />
<add name="cfmHandler" path="*.cfm" verb="*" modules="IsapiModule" scriptProcessor="C:\ColdFusion9\runtime\lib\wsconfig\jrun_iis6.dll" resourceType="Either" responseBufferLimit="0" />
<add name="jwsHandler" path="*.jws" verb="*" modules="IsapiModule" scriptProcessor="C:\ColdFusion9\runtime\lib\wsconfig\jrun_iis6.dll" resourceType="Either" responseBufferLimit="0" />
<add name="jspHandler" path="*.jsp" verb="*" modules="IsapiModule" scriptProcessor="C:\ColdFusion9\runtime\lib\wsconfig\jrun_iis6.dll" resourceType="Either" responseBufferLimit="0" />
</handlers>
<defaultDocument>
<files>
<add value="index.cfm" />
</files>
</defaultDocument>
<staticContent>
<mimeMap fileExtension=".air" mimeType="application/vnd.adobe.air-application-installer-package zip" />
</staticContent>
</system.webServer>
</configuration>
After editing, it now looks like this:
<configuration>
<system.webServer>
<staticContent>
</staticContent>
</system.webServer>
</configuration>
CF 10 is apparently using the isapi_redirect.dll for everything that used to be in the web.config.
** Also, please note that in CF 9, I had to change any sites not under default to use the defaultAppPool so they could inherit, as well as enabling ISAPI on the default site in handler mappings.
4) Run your localhost CFIDE/Administrator and it should come right up.
There may be a shortcut to all this, but it is what worked for me. Of course, now I've lost CF9.
