I have my browser set to delete *all* cookies when I close the browser and it seems consequent to that I loose all my 'local storage' settings on all the player sites. Consequently, I have to manualy reset each time I visit the sites. It would be so nice (and so simple) to have a simple default preference setting, instead of a non-user accessible fixed and limited storage value. In the meantime, can anyone suggest where I might look to hack the player default value?
[SOLVED]
This is a user 'hack' and thus *NOT CERTIFIED BY ADOBE* or any close affiliates!!!
This procedure also requires hacking a binary file so you need a hex editor.
1. Use your browser "Clear Recent History" options to delete all cookies, site preferences, cache, etc from your browsing history and *close* your browser.
2. Use Windows "My Computer" to browse your local file system to this path:
%APPDATA%\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\
3. Use a suitable Hex Editor to open and hack the 'settings.sol' file. I use a free editor called "WinVI".
( If you need it: http://www.winvi.de/ )
4. Go to the bottom of that 'settings.sol' file and look for 'defaultklimit'. The hex line should look like this:
64 65 66 61 75 6c 74 6b 6c 69 6d 69 74 00 40 59 defaultklimit.@Y
5. Very very carefully edit the '40' to new '60' value so your line now looks like this:
64 65 66 61 75 6c 74 6b 6c 69 6d 69 74 00 c0 00 defaultklimit. À
6. Double check to make sure the file size did not change during the edit in step 5. If it did then exit out without saving, come back in and try again. When you are sure your file size did not change after the edit, then save and exit out of the Hex Editor.
You should now have a new 'unliminted' storage default that remains even after browser option to clear all cache, site preferences, cookies, etc.
If you totally mess up the file, DON'T PANIC. Just delete the 'settings.sol' file and Flash Player will create a new file to replace it -- no worries, but do keep in mind this is a user 'hack' and thus *NOT CERTIFIED BY ADOBE* or any close affiliates!!!
If you use Linux, Mac or other OS then you might check this page to learn the location of that 'settings.sol' file:
https://en.wikipedia.org/wiki/Flash_cookie
Message was edited by: Pat Willener
[CORRECTION TO ORIGINAL POST]
After further review of my hack I learned it is essentially correct except for replacement values shown in step 5. Please substitute instructions in step 5 as follows:
5. Very very carefully edit the '40 59' to new 'c0 00' value so your line now looks like this:
Thanks for editing my original post Pat. Wanted to do that myself but didn't see the option. We missed a couple items in our edit though:
You missed this part >> ... edit the '40 59' to new 'c0 00'
And following the 'c0', I missed underline on '00' >> ... c0 00
It is important to edit both byte values (for those who know what a byte is).
