italyweb
Export html - Image files names
Jul 19, 2012 1:02 AM
I'm trying to create a project with an image (map of Italy) that highlight any region on mouseover (rollover).
Everything is fine, and when I preview on firefox it looks great.
Problem is that when i export it (export with images in a folder), it creates some strange names of these files (ie: no title_r1_c1_d1), that is not recognized by other html softwares (joomla).
Is there any way to export these file names with another name?
The project is really long and it would be impossible to rename these files when the have allready been exported, so I need to find a solution to tell fireworks to export them in a right format.
Thanks in advance
    Jul 19, 2012 9:39 AM   in reply to italyweb
    In Fireworks, try selecting the item in question and looking at the upper-left corner of the Properties inspector. There should be an image of the object and a label/description of the object. Immediately beneath that label is a text field. Try renaming the object there.
    Jul 19, 2012 10:15 PM   in reply to italyweb
    I'd suggest looking at the Export options (in the dialog that appears after choosing File > Export). For instance, maybe it would help to deselect "Include Areas without Slices".
    In addition, you could experiment with the HTML Setup options (by clicking the Options button in the above dialog or by choosing File > HTML Setup). For example, in the Document Specific section, there are file naming options for slices.
    Sorry, but there are a lot of variables and unknowns in what you're describing, and it's hard to narrow down what's happening. These are general suggestions.
Bookmarked By (1)
