How to know which channel is selected for the current document
Jul 18, 2012 3:39 AM
Tags: #select #classchannel #getter
In photoshop, open a CMYK file, by default the 4 channels are all selected. Now I just select one or two of them, In my plug-in code, how to know which channel is selected?
"Get Info Functions" chapter of "Automation Tutorial" introduces a getter function to get information from Photoshop, for "classChannel", there are 4 available keys: keyChannelName, keyItemIndex, keyCount, keyVisible, but none of them indicates if the channel is selected.
Now that we can play an event of selecting channel in photoshop, so I think there should be a way to get the selection status of the channels. Could any one give me some advice? Thanks very much.
    Jul 18, 2012 4:20 AM   in reply to Royt2011
    Every channel that is selected will have keyVisible true.
    Trouble is if you want to see which is selected from visible ones. I dont know for channels but it works for a layers so i suppose that it will work there too.
    When you perform action or get property on a layer if you use "enumTarget"  for adressing are done using currently active or selected or as implied by name  default targer layer.
    Now. if you want to know what is a current channel just get its name.
    Here is an example how to hide current  layer and any layer  using index.
    Unfortunately i have no time at the moment to writte exact cod that you need, but if this do not help post here and i will try to do when i can.
    N
    Hope this helps.
    Momir Zecevic
    Example
    // HideCurrentLayer
    SPErr AMAutoPlugin::HideCurrentLayer(void)
            SPErr error = kSPNoError;
            PIActionDescriptor result = NULL;
            PIActionDescriptor tempDescriptor = NULL;
            PIActionList tempList = NULL;
            PIActionReference tempReference = NULL;
            error = sPSActionDescriptor->Make(&tempDescriptor);
            if (error) goto returnError;
            error = sPSActionList->Make(&tempList);
            error = sPSActionReference->Make(&tempReference);
            error = sPSActionReference->PutEnumerated(tempReference, classLayer, typeOrdinal, enumTarget); //enumTarget - currently
            if (error) goto returnError;        //active -selected
            error = sPSActionList->PutReference(tempList, tempReference);
            error = sPSActionDescriptor->PutList(tempDescriptor, keyNull, tempList);
            error = sPSActionControl->Play(&result, eventHide, tempDescriptor, plugInDialogSilent);
    returnError:
            if (result != NULL) sPSActionDescriptor->Free(result);
            if (tempDescriptor != NULL) sPSActionDescriptor->Free(tempDescriptor);
            if (tempList != NULL) sPSActionList->Free(tempList);
            if (tempReference != NULL) sPSActionReference->Free(tempReference);
            return error;
    // HideLayerByIndex
    SPErr AMAutoPlugin::HideLayerByIndex(int32 index)
            error = sPSActionReference->PutIndex(tempReference, classLayer, index);
    returnError:
            return error;
