InDesign CS6 crashing and losing preferences
Jul 10, 2012 5:24 AM
I've had some terrible crashing in InDesign CS6 (and Acrobat). At least 2-3 times per day. When InDesign crashes, I lose my preferences and some of my workspace settings. Any fix for this?
Any fix for the crashing? It's inconsistent on when it crashes (saving, exporting, etc) and I've re-loaded the entire suite again. I'm running OSX Lion...
    Jul 10, 2012 6:00 AM   in reply to Stephanie USF
    Perhaps you are also being hit by this: http://forums.adobe.com/message/4548354
    Jul 18, 2012 4:14 PM   in reply to Stephanie USF
    You should try to figure out WHY your prefs keep going south. That's not normal.
    And in the meantime, after you get things set up, make a bhackup copy of the prefs files and store it someplace safe so you can relaod them easily. See Replace Your Preferences
    Jul 19, 2012 6:43 AM   in reply to Stephanie USF
    Most of the stuff that you are losing is stored in the InDesign Defaults file, not the SavedData file (that one saves the open recent list and the last state of a lot of stuff, but not the basic options you set in the prefs, or your document and print presets, which ARE saved in inDesign Defaults), so if that's the only one you can find, you'll at least get most things, and letting ID rewrite SavedData on close is not a big deal.
    That said, I wish I could tell you why you aren't seeing any InDesign stuff in youtr cache, but I can't, and I'm a Windows user so not as up on Mac idiosyncracies as I probably should be.
    Jul 19, 2012 6:46 AM   in reply to Stephanie USF
    And the next time you get a crash, please post it on pastebin.com and put a link to it here. Maybe we can figure out what the cause of the crash is.
    With absolutely no information toi go on I'll go out on a limb and suggest it very well could be font related. It won't hurt to run a font utility to look for damaged fonts, nor will it hurt to clear the font caches. Do you run a font manager?
    Jul 19, 2012 7:11 AM   in reply to Stephanie USF
    Jul 23, 2012 8:36 AM   in reply to Stephanie USF
    Jul 25, 2012 8:34 PM   in reply to Stephanie USF
    Although I have no answer as to why your ID keeps crashing, you can do this to restore your settings.
    Frist try resetting your preference as you did by restarting ID, then set your preferences again, then quit ID.
    Then go to the below directories and make a copy of the file "InDesign SavedData" and store it somewhere else.
    Users/[user]/Library/Caches/Adobe InDesign/Version [version]/InDesign SavedData
    If you happen to crash again and lose your settings, quit ID then replace the file in the above directory with your backup.
    Hope that helps.
    Message was edited by: j3n0
    Jul 26, 2012 9:44 AM   in reply to Stephanie USF
    They will be in your MacHD/Users/<yourusername>/Library/ folder but with OS10.7, the user Library folder is now a hidden folder. See here
    http://helpx.adobe.com/x-productkb/global/access-hidden-user-library-f iles.html
    Jul 26, 2012 9:46 AM   in reply to Stephanie USF
    Stephanie,
    Google how to show hidden files on OS X...
    Did you try the link I posted above for fixing a crash in 10.7.4?
    Jul 26, 2012 4:27 PM   in reply to Stephanie USF
    Stephanie,
    You need to go to the User Library, not the System, Library. To go there in Finder, press option then select "Go" menu, that will show the user Library folder and then you can to the respective folders.
    For your crashing issue, always check for any updates by going to Indesign then from the Help > Updates
    Jul 27, 2012 5:24 AM   in reply to Stephanie USF
    A couple of things. When I asked if you had tried the work-around for crashing above you said you weren't seeing blank dialogs, but I don't know if you actually downloaded and installed the files. I'm not sure you would notice the dialogs if you have the problem - they apparently flash by very fast before the crash.
    It's possible, given the new error message, that you have some corrupt data in the recovery folder and ID is now in a vicious cycle of crashing when it tries to recover the bad file. The recovery folder is also hidden, but should be in the same place you found InDesign SavedData. Please rename it to _InDesign Recovery and see if ID will start.
    Jul 27, 2012 5:36 AM   in reply to Stephanie USF
    If it stopped crashing, I think you can leave the recovery folder alone for now.
    Jul 27, 2012 6:15 AM   in reply to Stephanie USF
    Stephanie, I think I already mentioned that the Saved Data file is only one-half of the preferences set, and not the half that holds the things you keep resetting. Complete instructions are at Replace Your Preferences
    Aug 13, 2012 8:45 AM   in reply to Stephanie USF
    What other programs, inconsequential as you might think they are, do you have open?
    Do you have a font manager, or any other plugins from other vendors installed for ID? Constant crashing is far from the norm for CS6 and it almost always turns out to be some sort of system conflict on your computer if the procedures you've already tried are not working.
    Aug 13, 2012 9:02 AM   in reply to Stephanie USF
    Crashing in ID does not normally come with the territiory unless there is something wrong with a file. I don't think I see a crash in ID other than from a corupt file I'm testing more than once a year, if that.
    I'm on Windows, so my experience is differnt from yours, but I'd try turning off Stickies, AIM chat, Yahoo Messenger, and iTunes to start. What is "browse" in that list?
    You aren't running Hiss, are you? lots of other users reporting problems with it.
    Aug 28, 2012 9:53 AM   in reply to Stephanie USF
    Stephanie. Did you ever get this resolved? I have been using ID since 2.0 and since I upgraded to CS6 this has been happening.  VERY frustrating having to reset all my preferences every time.
    Aug 28, 2012 10:15 AM   in reply to Stephanie USF
    The only common app that I use is itunes.
    Maybe I will listen to pandora for a while and see if that helps me. Thanks.
