I'm having a problem with my Acrobat Pro X. I've downloaded from Creative Cloud using my login and password. When I open a PDF file Acrobat is closing down and then the Application Manager open. The dialogue box that appears shows a long text and a blue button. I click that button and Acrobat open. Then Acrobat Pro X closes and Application manager is up once again. This open and close scenario continue as long I try to use Acrobat.
Any idea you have is welcome to solve this problem. It started after I upgraded my operating system from OS X 10.6 to latest 10.7.4 if that is the problem. I'm currently downloading Acrobat Pro X again and try to install it to see if I manage to solve the opening and closing problem. I'll let you know how it works later. Please hit me with suggestions and ideas to stop this annoying opening and closing all the time, thank you.
Solved the problem! All I had to do was to re-install Acrobat. So, in case you should have similar problem, try to re-install the software. You will be asked about your log-in. Once you identified yourself the manager install and probably the wrong patch that made this problem is overrided.
have chatted with customer support and then had to leave to a meeting after an hour of various tries - deactivating, deleting cache files, deleting acrobat folder in my user profile, etc....NOTHING FIXED THIS PROBLEM!!!! Now trying to get back in contact w/ support and they are ALL BUSY!!
