LC_Polka
Viewer builder / Push certificates failure
Jul 19, 2012 12:59 AM
Tags: #push #builder #viewer #cs6 #certificat #csr
hello DPS community,
I'm facing a quite bothering issue with the viewer builder : I'm unable to load my push certificates (both development and prod).
Following the guidelines of the Adobe Production Guide, here's what I do :
1 - generate a CSR certificate
2 - generate the Devopment certificate and the p12 file
3 - generate the Production certificate and the p12 file
4 - generate the Push notification APS Production certificate and the APN Production p12 certificate
5 - generate the Push notification APS Development certificate and the APN Development p12 certificate
6 - generate the Development Mobileprovision certificate
7 - generate the Distribution Mobileprovision certificate
My three questions are :
> should I generate a CSR certificate for each and every step of the procedure ?
> is the order of the procedure correct ?
> is there a specific name under which the certificates have to be saved, in order to be correctly recognized by the viewer builder ?
I've scouting through the pages of the forum, and have seen this issue has been raised quite a few times... but couldn't find an answer !
Any help welcome !
(I'm running CS6 on Mac OS 10.7.4)
Laurent, Polka Magazine
    Jul 19, 2012 7:51 AM   in reply to LC_Polka
    What exact error did you get from Viewer Builder?
    regarding CSR - i would recomend to prepare new CSR for each step (with different names), sometimes i had hard times with correct exports of p12 files, instead of developer certificate i've exported distribution one or vice versa. Then i help myself with new keychain, where i import certs from Apple one by one, export and clean keychain.
    Regarding mobileprovision relation - you need to recreate mobileprovision files after push certificates are created/enabled.
    Jul 19, 2012 8:00 AM   in reply to LC_Polka
    Yeah, my favourite one, saw few times . Be very careful what you are exporting, i would suggest to create new keychain, import push certs from Apple there and export p12 push certs from this new keychain - one by one.
    Jul 19, 2012 8:31 AM   in reply to LC_Polka
    Yes, add dedicated keychain.
