SOLVED
Increase by one calendar day
Avatar
Level 9
The user enters a Monday date in a date/time object. It is, and needs to be displayed in full (Monday, July 16, 2012) When the user then clicks a check box object, the remaining days of that week are populated into four other date.time objects. I was trying to use the following FormCalc to verify the user selected a "Monday" date and if yes, then add one day for each other field but it does not work.
Here's an example form section -
// Get the number of days since epoch (Jan 1, 1900).
var dateNum = Date2Num(Day1.formattedValue,"M/D/YYYY")
// Convert the number of days to the full weekday name.
MondayCheck.rawValue = Num2Date(dateNum,"EEEE")
if (MondayCheck.rawValue ne "Monday") then
xfa.host.messageBox("First Requested Day Must Be a Monday.");
$.rawValue = "";
endif
DayTwo.Day2.rawValue = Num2Date(Date2num(Day1.rawValue,"YYYY-MM-DD")+1,"EEEE, MMMM D, YYYY");
DayThree.Day3.rawValue = Num2Date(Date2num(Day1.rawValue,"YYYY-MM-DD")+1,"EEEE, MMMM D, YYYY");
DayFour.Day4.rawValue = Num2Date(Date2num(Day1.rawValue,"YYYY-MM-DD")+1,"EEEE, MMMM D, YYYY");
DayFive.Day5.rawValue = Num2Date(Date2num(Day1.rawValue,"YYYY-MM-DD")+1,"EEEE, MMMM D, YYYY");
1 Accepted Solution
Avatar
Correct answer by
Level 10
Yup, it's FormCalc - you can't use Date2Num, etc., in JavaScript.
It will work with date fields but I found the text fields easier to deal with.
Avatar
Level 10
I've done something similar but found it easier to use more variables:
var endDate = Date2Num($,"YYYY-MM-DD")
var dayOfWeek = Num2Date(endDate, "E")
if (dayOfWeek <> 7) then
          xfa.host.messageBox("Ending date must be a Saturday")
          $ = null
          xfa.host.setFocus("$")
endif
and then I populate the other fields with this (I don't use date fields for the calculated dates, just text fields):
Pg1.subTableAux.Table1.Row1[6].Date = Num2Date(endDate - 0, "DD")
Pg1.subTableAux.Table1.Row1[5].Date = Num2Date(endDate - 1, "DD")
Pg1.subTableAux.Table1.Row1[4].Date = Num2Date(endDate - 2, "DD")
etc...
Avatar
Level 9
I assume this is in FormCalc. Do you know if this will work using date/time fields instead of textfields?
Thanks for your help,
-Don
Avatar
Correct answer by
Level 10
Avatar
Level 9
Thanks for your help!
I'll give it a try.
-Don
Avatar
Level 9
If I don't want this script to run unless a checkbox is checked first, how can I write a FormCalc statement for that>
Thanks again!
Avatar
Level 10
You'd need to wrap the whole thing in another if statement to check the value of the checkbox.
Or you could have the checkbox enable/disable the object that is doing the calculation.
Avatar
Level 9
That's the part I am not familiar with. I know javascript if statements but not FormCalc.
Is it like this:
if (checkbox1 = 1) then
etc...
Avatar
Level 10
Yup it works the same but the FormCalc operators seem to work better (eq instead of =, <> instead of !=, etc.).
if (condition) then
     if (condition) then
          do stuff
     endif
endif
Here's a link to the FormCalc user reference:
http://help.adobe.com/en_US/livecycle/9.0/FormCalc.pdf
Avatar
Level 9
Got it - thanks for your time and expertise.
-Don
