I have text that I live traced and I am trying to mask vertical lines through the letters. When I do this the text turns white. When I ungroup and do it one at a time only one letter works the others turn white. When I use make a compound path still only one letter will work and the other letters turn white.
Please help, I just purchase CS6 and I have not had time to do tutorials and I have a deadline to meet...
Thank you,
T
The letter forms are probably grouped
1. Ungroup them, you might have ti use the ungroup command more than once or twice.
2. while all the letters are still selected make the text art a compund path (even if the option to release a compund path is present.)
3. make sure the letters are in font of the lines
4. select all and make your clipping mask
I got it now you live trace and expand text image
then ungroup
then flatten the transparency 100% vector as the settings
then make a compund path
now you can successfully the clipping mask and the letters will mask the art.
Flattening the transparency seems to be the important ingredient.
This was traced from a text image expanded ungrouped flatten the transparency made a compound path and then the clipping mask. Voila!
