Increase by one calendar day
Jul 19, 2012 9:40 AM
The user enters a Monday date in a date/time object. It is, and needs to be displayed in full (Monday, July 16, 2012) When the user then clicks a check box object, the remaining days of that week are populated into four other date.time objects. I was trying to use the following FormCalc to verify the user selected a "Monday" date and if yes, then add one day for each other field but it does not work.
Here's an example form section -
// Get the number of days since epoch (Jan 1, 1900).
var dateNum = Date2Num(Day1.formattedValue,"M/D/YYYY")
// Convert the number of days to the full weekday name.
MondayCheck.rawValue = Num2Date(dateNum,"EEEE")
if (MondayCheck.rawValue ne "Monday") then
xfa.host.messageBox("First Requested Day Must Be a Monday.");
$.rawValue = "";
endif
DayTwo.Day2.rawValue = Num2Date(Date2num(Day1.rawValue,"YYYY-MM-DD")+1,"EEEE, MMMM D, YYYY");
DayThree.Day3.rawValue = Num2Date(Date2num(Day1.rawValue,"YYYY-MM-DD")+1,"EEEE, MMMM D, YYYY");
DayFour.Day4.rawValue = Num2Date(Date2num(Day1.rawValue,"YYYY-MM-DD")+1,"EEEE, MMMM D, YYYY");
DayFive.Day5.rawValue = Num2Date(Date2num(Day1.rawValue,"YYYY-MM-DD")+1,"EEEE, MMMM D, YYYY");
    Jul 19, 2012 11:53 AM   in reply to DKinsley
    I've done something similar but found it easier to use more variables:
    var endDate = Date2Num($,"YYYY-MM-DD")
    var dayOfWeek = Num2Date(endDate, "E")
    if (dayOfWeek <> 7) then
              xfa.host.messageBox("Ending date must be a Saturday")
              $ = null
              xfa.host.setFocus("$")
    endif
    and then I populate the other fields with this (I don't use date fields for the calculated dates, just text fields):
    Pg1.subTableAux.Table1.Row1[6].Date = Num2Date(endDate - 0, "DD")
    Pg1.subTableAux.Table1.Row1[5].Date = Num2Date(endDate - 1, "DD")
    Pg1.subTableAux.Table1.Row1[4].Date = Num2Date(endDate - 2, "DD")
    etc...
    Jul 19, 2012 12:16 PM   in reply to DKinsley
    Yup, it's FormCalc - you can't use Date2Num, etc., in JavaScript.
    It will work with date fields but I found the text fields easier to deal with.
    Jul 19, 2012 12:44 PM   in reply to DKinsley
    You'd need to wrap the whole thing in another if statement to check the value of the checkbox.
    Or you could have the checkbox enable/disable the object that is doing the calculation.
    Jul 19, 2012 12:56 PM   in reply to DKinsley
    Yup it works the same but the FormCalc operators seem to work better (eq instead of =, <> instead of !=, etc.).
    if (condition) then
         if (condition) then
              do stuff
         endif
    endif
    Here's a link to the FormCalc user reference:
    http://help.adobe.com/en_US/livecycle/9.0/FormCalc.pdf
