New Disk setup help
Jul 19, 2012 5:10 AM
I"d like to ask your help, or suggetions.I read the forum lots of conversations about disk setup, but Im not sure this is a good choice.I planned this setup:I have lga2011 platform.
C :  OCZ revodrive X2 160GB - OS ( I already have )
D :  2* 1TB Samsung SpinpointF3  7200rpm HD103SJ RAID 0 - Media cache, previews, pagefile
( I already have )
E :  4* 1TB 7200rpm RAID 3 for media, project files - WD RE4 1 TB ( WD1003FBYX) or
        - Saegate Barracuda ST1000DM003 or
        - Samsung SP F3
    I dont have yet, HItachi  too expensive for me.
F : Corsair Force 3 240GB SSD - AE CS6 Global Preformance cache ( I already have it)
G : Samsung 830 128GB SSD - Exports ( I dont have yet)
+ a RAID controller.I looked out Areca 1182ix/12, but Im afraid its too expensive for this setup.
- Do you know other type RAID controller which good for this config?
- What do you think about drive E, what is the good choice?
- Same question about drive G ?
Any advice would help!Thanks in advance.
    Jul 19, 2012 6:16 AM   in reply to Dvico
    Is that a typo and did you mean the 1882ix/12? With a plethora of disks in your configuration, maybe the 8-port version would suffice and save some $$.
    For the E: drive I think the RE4 is a good choice. The Samsung F3 is a good second IMO.
    For the G: drive the Samsung is a good choice, much more affordable than the Corsair Performance Pro and almost as fast. I would suggest a 256 GB version to have some more space however.
    Jul 19, 2012 9:20 AM   in reply to Dvico
    You are correct that the cache on the 8-port model can not be increased, but with SATA3 disks with 64 GB cache, that is not a major problem. If you are only using 4 disks in an array, it simply means when you are under budget constraints, you have to chose. In your case I suggested the 8-port with some cache limitations, because chances are you will not outgrow the number of ports soon and the impact of the expandable cache is small. The on-board cache memory on the 8-port model is still comparable to other brands.
