Hi !
i have been trying to fix this problem for a whole day now!
I am very new to the program and i think i might of clicked something off to disable the preview but i dont know what i pressed !
Basically, i want to preview the Pre-Compose only with the Control key so i can hear the song (Making a lyric video) but for some reason it doesnt work anymore!
Any ideas what can it be ? (it worked yesterday)
Using After Effects CS4 !
Highlight the footage in the project window. Look at the information about it at the very top, where you see a thumbnail. Write it down. Report back.
It sounds like you've jumped right into the deep end of the pool with AE. That's a very, VERY bad idea. AE contains too many ways to completely hose the uninitiated. You can't just start using it for the first time with no knowledge of th4 AE basics and expect good things to happen.
Fortunately, there's a solution to that, and you'll find it right here.
Don't sweat being a newbie Hayden, we were all there once. I've been using it for years, have completed feature films with it, and still feel like i know nothing.
It sounds like you don't have any audio in your pre-composition. If you have audio on the top layer and pre-compose it, it doesn't necessarily mean that it came with it. Do you have a layer with audio in the precomp?
Select your audio layer, cut, then paste in your pre-comp. You can also copy and paste but there's a potential problem with that.
You don't want two copies of the same audio in the same final comp. If you need a copy of the audio in the pre-comp just for reference, then make sure you turn it off when you go back to the main comp. If you don't your final render will most likely have audio problems.
