Friends and neighbors, my previous discussion thread, "Slow Browsing Since Update," went unanswered. Anyway, if I am going to view flash in SeaMonkey, having quit finding an alternative program that works, then I will have to get Flash Player to work. However, having downloaded and installed it, it does not appear on SeaMonkey's list of Addons. Why?
Pat, in the system32 folder I have Flash64_11_3_300_265.ocx, FlashInstall, FlashUtil64_11_3_300_265_ActiveX.dll, FlashUtil64_11_3_300_265_ActiveX.exe, FlashUtil64_11_3_300_265_Plugin.exe and NPSWF64_11_3_300_265.dll. In the system64 folder I have Flash32_11_3_300_265.ocx, FlashInstall, flashplayer.xpt, FlashPlayerPlugin_11_3_300_265.exe, FlashPlayerUpdateService.exe, FlashUtil32_11_3_300_265_ActiveX.dll, FlashUtil32_11_3_300_265_ActiveX.exe, FlashUtil32_11_3_300_265_Plugin.exe, mms.cfg, and NPSWF32_11_3_300_265.dll.
I have installed Seamonkey, and the Shockwave Flash plugin shows up normally. It also works normally.
I have observed the startup of Seamonkey using Process Monitor, and it uses the same technique to load the Flash Plugin as Firefox, via HKLM\SOFTWARE\Wow6432Node\MozillaPlugins\@adobe.com/FlashPlayer\Path
Questions:
Pat, to answer your first question, no. To your second question, if I interpret it correctly, I am now doing a search since I cannot spot the HKLM prefix. Now that the search is over, I cannot find it. Sorry, but I need to know where in regedit to look. Thank you for getting back to me on this hot, busy weekend.
What you should do next is the following...
Download Process Monitor and unzip it, then run it.
At the start it will present you with a Filter panel. Under 'Display entries matching these' enter Process name is seamonkey, and click the Add button.
Click OK, then start and stop Seamonkey.
Now use the Find function (Ctrl+F) to look for NPSWF; maybe you will be able to find why SM does not load the Shockwave Flash plugin.
If it doesn't find anything NPSWF, then look for MozillaPlugins.
You can also save the entire ProcMon output and post it here, or send it to me via email; I will send you a PM with my email address.
This forum editor has a knack jumping around when trying to insert a hyperlink...
Here is the correct link:
http://technet.microsoft.com/en-us/sysinternals/bb896645.aspx
Pat, you'll never guess what happened! Earlier this evening I ran SuperAntiSpyware. Last week on Thursday, July 19, 2012 I downloaded a version of Flash Player to my Downloads folder. Look what the scan revealed: Heur.Agent/Gen-WhiteBox in C:\USERS\USER\DOWNLOADS\FLASHPLAYERSETUP.EXE. Of course I removed it; so it is no longer in the Downloads folder. However, when I reopened SeaMonkey Mail & Newsgroups, it opened up a group of tabs. One of them is http://helpx.adobe.com/flash-player/kb/find-version-flash-player.html. In the movie box it shows a ball rolling back and forth. Above it there is a message, "Flash player is running on your system." I do not know why this shows, but maybe the scan caused it. Anyway, should I carry out the directions with Process Monitor?
Pat, since recent updates to Flash Player and, coincidentally Java, SeaMonkey has worked so slowly that tonight it froze my entire system. Under Tools, the Clear Private Data function once worked quickly; but not it takes a few minutes during which time I could not open production programs like Publisher. Also, other functions that respond quickly such as the normal Windows Control Panel would not open. Even my mouse driver froze. I have had SeaMonkey for almost two years, working fine until these recent updates to Flash Player and Java. I just started my fourth thread on SeaMonkey's Bugzilla site. If there is no solution to fix SeaMonkey, then I will have to uninstall it and replace it with another default email client.
