How to reset/restart timer?
Jul 20, 2012 2:23 AM
hello everyone
i am trying to restart my timer. i used
timer.reset();
but it won't work..
so i tried
timer.stop();
timer.reset();
timer.start();
and this is also not working.. timer is not reseting..
So can anyone tell me How can I restart my timer??
    Jul 20, 2012 4:32 AM   in reply to sachin_mak
    What you show should work.  It would also work without the timer.stop();  Maybe you should work it out in a separate file first to make sure you have everything proerly mapped.  Here's some code that works to help demo it:
    var tm:Timer = new Timer(1000, 20);
    function reportCount(evt:TimerEvent):void {
        trace(String(tm.currentCount));
    tm.addEventListener(TimerEvent.TIMER, reportCount);
    stage.addEventListener(MouseEvent.CLICK, restartClock);
    function restartClock(evt:MouseEvent):void {
        tm.reset();
        tm.start();
    tm.start();
    Jul 24, 2012 2:03 AM   in reply to sachin_mak
    Please check below code.
    import flash.events.TimerEvent;
    import com.greensock.TimelineLite;
    var timer:Timer = new Timer(1000,0);
    timer.addEventListener(TimerEvent.TIMER,checkTime)
    timer.start();
    // This function is required so that once getTimer() will give you required number i.e. 1500 reset function will be called
    function checkTime(e:TimerEvent)
          var cTime:int = getTimer();
          trace(cTime + " " + timer.currentCount) // currentCount will show that timer is restarted,
          if(cTime>=15000 && cTime<=16000)
                 ResetTime();
    function ResetTime():void
          trace("ResetTime")
          timer.stop();
          timer.reset();
          timer.start();
    Hope that will solve your problem
    Regards
    Ritesh Newal
