amaronee1
Indesign CS5 crashing repeatedly.
Jul 18, 2012 11:51 PM
I've been using Indesign CS5 for about a year now, migrating from Quark. It's been remarkably stable, running on my iMac OSX10.6.8, 2.4 GHz Intel Core 2 Duo w/4 GB SDRAM. Then suddenly today, one particular file starated crashing repeatedly.  I ran Disc Utility off an other start-up drive, repaired permissions; everything checked out OK. Still crashing. I created new docs and dragged thumbnails page by page trying to ID the offending page, but every doc of this lineage crashes. (It would take a long time to rebuild from scratch.) The original doc became unrecoverable. The original crashing file had a couple rows of type on a circular path and I wondered if that was the problem.  I deleted my .plist. Finally, I uninstalled and reinstalled the entire Creative Suite5. Still crashing. Any ideas? I need to be up and running for my work. Many thanks, Dianne,
    Jul 19, 2012 1:09 AM   in reply to amaronee1
    Sounds like a corrupt document http://forums.adobe.com/thread/526991
    From time to time code can build up on saves - or items within a page become corrupt.
    If the link there doesn't work wholly for you then I suggest another method - divide and conquer.
    When files become murky like this I will take the file and split in half - and then see which document crashes or becomes unstable.
    I then take that file again, and split in half again. Then eventually I can whittle it down to a page range - and usually rebuilding this small page range will fix the issue.
    Jul 19, 2012 1:28 AM   in reply to Eugene Tyson
    Just to add - do this on a COPY of the original! Don't want to lose the file if something wonky happens.
    Jul 19, 2012 6:27 AM   in reply to amaronee1
    It might be very helpful to see one o fhte crash reports. You can post it on pastebin.com and put a link here.
    In addition to Eugene's suggestion, try opening the file as a copy. Sometimes that works, too.
    When all else fails, and the file is worth the expense of the service, Markzware offers a corrupt file recovery service on a no-recovery, no-fee (other than a nominal take-in charge) basis. You can learn more about that at Bad InDesign or Quark File Recovery Submission Form
    Jul 19, 2012 8:50 AM   in reply to amaronee1
    Was this file converted form Quark originally, or made entirely in ID? Converted files often have little problems that can become big ones down the road and a good practice is to always export to .inx/.idml after conversion.
    Jul 19, 2012 8:53 AM   in reply to amaronee1
    I'm a Windows user (and I think Eugene is too), but if memory serves the Mack should al least offer to generate the report automatically, if not actually make it.
    Amy Mac lurker care to elaborate on finding it?
    Jul 19, 2012 9:24 AM   in reply to amaronee1
    Jul 20, 2012 5:04 AM   in reply to amaronee1
    Any luck with this?
    I've been corresponding with David Dilling of Markzware (a conversation not triggered by this thread, but relevant) who has decided to offer a 50% discount, on a trial basis, for first-time users of the InDesign file recovery service who learn about it here on the forum. The discount will apply to the recovery fee, if there is a successful recovery, but will not apply to the file takein fee. He says for the moment forum users who want to use the service for the first time should include their forum username and the URL of the thread where they learned about the service when they submit their file.
    Jul 21, 2012 12:22 PM   in reply to amaronee1
    Could be a bad font, or corrupt font cache (you can use a utility like Cocktail to clear the caches). Do you run a font manager?
    It would REALLY be helpful to see the crash reports...
    Jul 21, 2012 6:41 PM   in reply to amaronee1
    You might first try updating to version 7.0.4 instead of the 7.0.0 listed in the crash log.
    Jul 22, 2012 4:40 AM   in reply to amaronee1
    As Larry says, you ABSOLUTELY need to apply the 7.0.4 patch. If it doesn't come up when you try Updates from the ID help menu, go to http://www.adobe.com/support/downloads/detail.jsp?ftpID=5004 and dowload and install it manually.
    The crash report seems to indicate to me a problem in the user interface, rather than a font problem, so hopefully the update will fix things. There were quite a few bug fixes.
    Jul 22, 2012 9:15 AM   in reply to amaronee1
    That one is definitely text related. Try substituting another font for the Nevis temporarily and see if it stops crashing.
    Jul 24, 2012 4:30 AM   in reply to amaronee1
    Try substituting ANYTHING else for the nevis and see if it will export without crashing.
    ID is very picky about fonts, and fonts that are slightly defective and may still work in other applications can be problems in ID. You may need to find a different font.
    Jul 25, 2012 4:52 PM   in reply to amaronee1
    If you have the time, make a copy of the file and change ALL of the type to one font that you know is OK. Doe it work? That will tell you if the problem is a font, or maybe the type on a path.
    Start adding back fonts until it fails (you can do it groups to make it faster if you have a lot of fonts to add).
    Jul 26, 2012 6:34 AM   in reply to amaronee1
    Yes, it's entirely possible the fonts are fine and there's a problem in the file itself or new bug you've discovered, but the only way to know is to dig deeper, and my suggestion was the first diagnostic elimination step.
    Jul 26, 2012 12:13 PM   in reply to amaronee1
    Starting to sound like some other software running on your system is corrupting ID files...
