Packaging ipa not working any more with AIR 3.3
Jun 15, 2012 9:45 AM
Tags: #air #ios #extension #ane #packaging #3.3 #native
Hello,
I use a custom ANE that worked without any problems on AIR 3.0, 3.1 and 3.2. Since I updated the ipa doesn't even compile any more. I get the following output on the command line on Windows and MacOS:
K:\MyFiles\src\iOS\word smith pro>c:\air\bin\adt -package  -target ipa-test -storetype pkcs12 -keystore iphone_dev.p12 -provisioning-profile development.mobileprovision  wordSmithPro.ipa wordSmith-app-xml.xml WordSmithMob.swf icons sounds dicts -extdir "native"
password:
ld: warning: -ios_version_min not specificed, assuming 4.0
ld: warning: ignoring file C:\\Users\\Henning\\AppData\\Local\\Temp\\ca8c0034-79
68-44dd-9859-0abb8a07e41b/libcom.devarai.MyAD.a, file was built for archive whic
h is not the architecture being linked (armv7)
ld: warning: CPU_SUBTYPE_ARM_ALL subtype is deprecated: C:\\air\\lib\\aot/lib/cr
t1.o
ld: warning: CPU_SUBTYPE_ARM_ALL subtype is deprecated: C:\\air\\lib\\aot/lib/gc
c/libgcc.a(_addsubdf3.o)
c/libgcc.a(_fixunsdfdi.o)
c/libgcc.a(_udivdi3.o)
c/libgcc.a(_umoddi3.o)
c/libgcc.a(_modsi3.o)
c/libgcc.a(_udivsi3.o)
c/libgcc.a(_umodsi3.o)
c/libgcc.a(_divsi3.o)
c/libgcc.a(_dvmd_tls.o)
c/libgcc.a(_clz.o)
c/libgcc.a(_fixdfsi.o)
c/libgcc.a(_fixunsdfsi.o)
c/libgcc.a(_divdi3.o)
c/libgcc.a(_addsubsf3.o)
c/libgcc.a(_fixdfdi.o)
c/libgcc.a(_moddi3.o)
c/libgcc.a(_cmpdf2.o)
c/libgcc.a(_muldivdf3.o)
c/libgcc.a(_unorddf2.o)
ld: warning: ARM function not 4-byte aligned: _IDctSlow_ARM from C:\\air\\lib\\a
ot/lib/libRuntimeAOT.arm-air.a(idct_part.o)
ld: warning: ARM function not 4-byte aligned: IDctSlowProcessRowLoop from C:\\ai
r\\lib\\aot/lib/libRuntimeAOT.arm-air.a(idct_part.o)
ld: warning: ARM function not 4-byte aligned: IDctSlowSkipArithmeticInRow from C
:\\air\\lib\\aot/lib/libRuntimeAOT.arm-air.a(idct_part.o)
ld: warning: ARM function not 4-byte aligned: IDctSlowProcessColumnLoop from C:\
ld: warning: ARM function not 4-byte aligned: IDctSlowConstantxC1S7 from C:\\air
ld: warning: ARM function not 4-byte aligned: IDctSlowConstantTable from C:\\air
ld: warning: ARM function not 4-byte aligned: IDctSlowConstantxC7S1 from C:\\air
ld: warning: ARM function not 4-byte aligned: IDctSlowConstantxC3S5 from C:\\air
ld: warning: ARM function not 4-byte aligned: IDctSlowConstantxC5S3 from C:\\air
ld: warning: ARM function not 4-byte aligned: IDctSlowConstantxC4S4 from C:\\air
ld: warning: ARM function not 4-byte aligned: IDctSlowConstantxC2S6 from C:\\air
ld: warning: ARM function not 4-byte aligned: IDctSlowConstantxC6S2 from C:\\air
ld: warning: ARM function not 4-byte aligned: _IDct10_ARM from C:\\air\\lib\\aot
ld: warning: ARM function not 4-byte aligned: IDct10ComputeRow0 from C:\\air\\li
ld: warning: ARM function not 4-byte aligned: IDct10ComputeRow1 from C:\\air\\li
ld: warning: ARM function not 4-byte aligned: IDct10ComputeRow2 from C:\\air\\li
ld: warning: ARM function not 4-byte aligned: IDct10ComputeRow3 from C:\\air\\li
ld: warning: ARM function not 4-byte aligned: IDct10_skip_Row3 from C:\\air\\lib
ld: warning: ARM function not 4-byte aligned: IDct10ProcessColumns from C:\\air\
ld: warning: ARM function not 4-byte aligned: IDct10ProcessColumnLoop from C:\\a
ld: warning: ARM function not 4-byte aligned: IDct10Fill2WithZero from C:\\air\\
ld: warning: ARM function not 4-byte aligned: IDct10Fill1WithZero from C:\\air\\
ld: warning: ARM function not 4-byte aligned: IDct10Fill0WithZero from C:\\air\\
ld: warning: ARM function not 4-byte aligned: _IDct1_ARM from C:\\air\\lib\\aot/
ld: warning: ARM function not 4-byte aligned: _IDCT1_plus_ReconBlock_ARM from C:
ld: warning: ARM function not 4-byte aligned: IDCT1_plus_ReconBlock_loop from C:
ld: warning: ARM function not 4-byte aligned: _IDCT1_plus_ReconInter_ARM from C:
ld: warning: ARM function not 4-byte aligned: IDCT1_plus_ReconInter_loop from C:
ld: warning: ARM function not 4-byte aligned: _FilterBlock1dH_ARM11 from C:\\air
\\lib\\aot/lib/libRuntimeAOT.arm-air.a(predfilters.o)
ld: warning: ARM function not 4-byte aligned: loop1 from C:\\air\\lib\\aot/lib/l
ld: warning: ARM function not 4-byte aligned: _FilterBlock1dV_ARM11 from C:\\air
ld: warning: ARM function not 4-byte aligned: loop3 from C:\\air\\lib\\aot/lib/l
ld: warning: ARM function not 4-byte aligned: loop4 from C:\\air\\lib\\aot/lib/l
ld: warning: ARM function not 4-byte aligned: _FilterBlock2dFirstPass_ARM11 from
C:\\air\\lib\\aot/lib/libRuntimeAOT.arm-air.a(predfilters.o)
ld: warning: ARM function not 4-byte aligned: loop5 from C:\\air\\lib\\aot/lib/l
ld: warning: ARM function not 4-byte aligned: _FilterBlock1dBilH_ARM11 from C:\\
ld: warning: ARM function not 4-byte aligned: FilterBlock1dBilH_next_row from C:
ld: warning: ARM function not 4-byte aligned: _FilterBlock1dBilV_ARM11 from C:\\
ld: warning: ARM function not 4-byte aligned: FilterBlock1dBilV_outer_loop from
ld: warning: ARM function not 4-byte aligned: FilterBlock1dBilV_inner_loop from
ld: warning: ARM function not 4-byte aligned: _FilterBlock2dBil_FirstPass_ARM11
from C:\\air\\lib\\aot/lib/libRuntimeAOT.arm-air.a(predfilters.o)
ld: warning: ARM function not 4-byte aligned: FilterBlock2dBil_FirstPass_next_ro
w from C:\\air\\lib\\aot/lib/libRuntimeAOT.arm-air.a(predfilters.o)
ld: warning: ARM function not 4-byte aligned: _Copy12x12_ARM9E from C:\\air\\lib
\\aot/lib/libRuntimeAOT.arm-air.a(copy12x12.o)
ld: warning: ARM function not 4-byte aligned: Copy12x12_CSrcAlign0 from C:\\air\
\lib\\aot/lib/libRuntimeAOT.arm-air.a(copy12x12.o)
ld: warning: ARM function not 4-byte aligned: Copy12x12_CSrcAlign1 from C:\\air\
ld: warning: ARM function not 4-byte aligned: Copy12x12_CSrcAlign2 from C:\\air\
ld: warning: ARM function not 4-byte aligned: Copy12x12_CSrcAlign3 from C:\\air\
ld: warning: ARM function not 4-byte aligned: _ReconIntra_ARM11 from C:\\air\\li
b\\aot/lib/libRuntimeAOT.arm-air.a(reconstruct-F6251070C86EBC8D.o)
ld: warning: ARM function not 4-byte aligned: loop from C:\\air\\lib\\aot/lib/li
ld: warning: ARM function not 4-byte aligned: _ReconInter_ARM11 from C:\\air\\li
ld: warning: ARM function not 4-byte aligned: _ReconBlock_ARM11 from C:\\air\\li
ld: warning: ARM function not 4-byte aligned: ReconBlock_ARM11_LOOP from C:\\air
\\lib\\aot/lib/libRuntimeAOT.arm-air.a(reconstruct-F6251070C86EBC8D.o)
ld: warning: ARM function not 4-byte aligned: _tDecodeBool from C:\\air\\lib\\ao
t/lib/libRuntimeAOT.arm-air.a(tDecodeBool.o)
ld: warning: ARM function not 4-byte aligned: _tDecodeBool128 from C:\\air\\lib\
\aot/lib/libRuntimeAOT.arm-air.a(tDecodeBool.o)
Undefined symbols for architecture armv7:
  "_ExtInitializer", referenced from:
      _g_com_adobe_air_fre_fmap in extensionglue.o
     (maybe you meant: _ExtInitializer_name)
  "_ExtFinalizer", referenced from:
     (maybe you meant: _ExtFinalizer_name)
ld: symbol(s) not found for architecture armv7
Compilation failed while executing : ld64
    Jun 19, 2012 9:37 PM   in reply to Devarai
    The only thing I can think of is AIR 3.3 ships with the iOS 5 SDK. Would that change anything?
    Randy Nielsen
    Senior Content and Community Manager
    Adobe Systems Incorporated
    Jun 19, 2012 9:51 PM   in reply to Devarai
    You ANE must contain some armv6 symbols. You need to compile your native code again for armv7 only.
    Jul 20, 2012 1:44 AM   in reply to neh@adobe
    Kind of same thing happening with SDK 3.1 build where I'm also passing -platformsdk (IOS SDK 5.0 path) to the ADT. The IPA is generating but a lots of warning, and even when I'm running the IPA on device, its terminated with strange errors. I've investigated that its with other 'stageVideo' functionalities in the app and when I'm trying to close the stream by 'stream.close()' and 'stream.dispose()'. If I cut-off the -platformsdk in the adt build, then the app works fine, but the IOS 5.0 specific things apparently not working. I've also did 'armv7' only in the XCode.
    Following is the command-line for the adt that I'm using:
    /Applications/Adobe\ Flash\ Builder\ 4.6/sdks/4.6.0/bin/adt -package -target ipa-test-interpreter -provisioning-profile <myprofile>.mobileprovision -storetype pkcs12 -keystore Certificates.p12 <myipa>.ipa <myapp>-app.xml <myswf>.swf -extdir ../ext/ -platformsdk /Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS5.0.sdk /
    Here's the warning while build:
    ld: warning: ARM function not 4-byte aligned: _IDctSlow_ARM from /Applications/Adobe Flash Builder 4.6/sdks/4.6.0/lib/aot/lib/libRuntimeInterpreter.arm-air.a(idct_part. o)
    ld: warning: ARM function not 4-byte aligned: IDctSlowProcessRowLoop from /Applications/Adobe Flash Builder 4.6/sdks/4.6.0/lib/aot/lib/libRuntimeInterpreter.arm-air.a(idct_part. o)
    ld: warning: ARM function not 4-byte aligned: IDctSlowSkipArithmeticInRow from /Applications/Adobe Flash Builder 4.6/sdks/4.6.0/lib/aot/lib/libRuntimeInterpreter.arm-air.a(idct_part. o)
    ld: warning: ARM function not 4-byte aligned: IDctSlowProcessColumnLoop from /Applications/Adobe Flash Builder 4.6/sdks/4.6.0/lib/aot/lib/libRuntimeInterpreter.arm-air.a(idct_part. o)
    ld: warning: ARM function not 4-byte aligned: IDctSlowConstantxC1S7 from /Applications/Adobe Flash Builder 4.6/sdks/4.6.0/lib/aot/lib/libRuntimeInterpreter.arm-air.a(idct_part. o)
    ld: warning: ARM function not 4-byte aligned: IDctSlowConstantTable from /Applications/Adobe Flash Builder 4.6/sdks/4.6.0/lib/aot/lib/libRuntimeInterpreter.arm-air.a(idct_part. o)
    ld: warning: ARM function not 4-byte aligned: IDctSlowConstantxC7S1 from /Applications/Adobe Flash Builder 4.6/sdks/4.6.0/lib/aot/lib/libRuntimeInterpreter.arm-air.a(idct_part. o)
    ld: warning: ARM function not 4-byte aligned: IDctSlowConstantxC3S5 from /Applications/Adobe Flash Builder 4.6/sdks/4.6.0/lib/aot/lib/libRuntimeInterpreter.arm-air.a(idct_part. o)
    ld: warning: ARM function not 4-byte aligned: IDctSlowConstantxC5S3 from /Applications/Adobe Flash Builder 4.6/sdks/4.6.0/lib/aot/lib/libRuntimeInterpreter.arm-air.a(idct_part. o)
    ld: warning: ARM function not 4-byte aligned: IDctSlowConstantxC4S4 from /Applications/Adobe Flash Builder 4.6/sdks/4.6.0/lib/aot/lib/libRuntimeInterpreter.arm-air.a(idct_part. o)
    ld: warning: ARM function not 4-byte aligned: IDctSlowConstantxC2S6 from /Applications/Adobe Flash Builder 4.6/sdks/4.6.0/lib/aot/lib/libRuntimeInterpreter.arm-air.a(idct_part. o)
    ld: warning: ARM function not 4-byte aligned: IDctSlowConstantxC6S2 from /Applications/Adobe Flash Builder 4.6/sdks/4.6.0/lib/aot/lib/libRuntimeInterpreter.arm-air.a(idct_part. o)
    ld: warning: ARM function not 4-byte aligned: _IDct10_ARM from /Applications/Adobe Flash Builder 4.6/sdks/4.6.0/lib/aot/lib/libRuntimeInterpreter.arm-air.a(idct_part. o)
    ld: warning: ARM function not 4-byte aligned: IDct10ComputeRow0 from /Applications/Adobe Flash Builder 4.6/sdks/4.6.0/lib/aot/lib/libRuntimeInterpreter.arm-air.a(idct_part. o)
    ld: warning: ARM function not 4-byte aligned: IDct10ComputeRow1 from /Applications/Adobe Flash Builder 4.6/sdks/4.6.0/lib/aot/lib/libRuntimeInterpreter.arm-air.a(idct_part. o)
    ld: warning: ARM function not 4-byte aligned: IDct10ComputeRow2 from /Applications/Adobe Flash Builder 4.6/sdks/4.6.0/lib/aot/lib/libRuntimeInterpreter.arm-air.a(idct_part. o)
    ld: warning: ARM function not 4-byte aligned: IDct10ComputeRow3 from /Applications/Adobe Flash Builder 4.6/sdks/4.6.0/lib/aot/lib/libRuntimeInterpreter.arm-air.a(idct_part. o)
    ld: warning: ARM function not 4-byte aligned: IDct10_skip_Row3 from /Applications/Adobe Flash Builder 4.6/sdks/4.6.0/lib/aot/lib/libRuntimeInterpreter.arm-air.a(idct_part. o)
    ld: warning: ARM function not 4-byte aligned: IDct10ProcessColumns from /Applications/Adobe Flash Builder 4.6/sdks/4.6.0/lib/aot/lib/libRuntimeInterpreter.arm-air.a(idct_part. o)
    ld: warning: ARM function not 4-byte aligned: IDct10ProcessColumnLoop from /Applications/Adobe Flash Builder 4.6/sdks/4.6.0/lib/aot/lib/libRuntimeInterpreter.arm-air.a(idct_part. o)
    ld: warning: ARM function not 4-byte aligned: IDct10Fill2WithZero from /Applications/Adobe Flash Builder 4.6/sdks/4.6.0/lib/aot/lib/libRuntimeInterpreter.arm-air.a(idct_part. o)
    ld: warning: ARM function not 4-byte aligned: IDct10Fill1WithZero from /Applications/Adobe Flash Builder 4.6/sdks/4.6.0/lib/aot/lib/libRuntimeInterpreter.arm-air.a(idct_part. o)
    ld: warning: ARM function not 4-byte aligned: IDct10Fill0WithZero from /Applications/Adobe Flash Builder 4.6/sdks/4.6.0/lib/aot/lib/libRuntimeInterpreter.arm-air.a(idct_part. o)
    ld: warning: ARM function not 4-byte aligned: _IDct1_ARM from /Applications/Adobe Flash Builder 4.6/sdks/4.6.0/lib/aot/lib/libRuntimeInterpreter.arm-air.a(idct_part. o)
    ld: warning: ARM function not 4-byte aligned: _IDCT1_plus_ReconBlock_ARM from /Applications/Adobe Flash Builder 4.6/sdks/4.6.0/lib/aot/lib/libRuntimeInterpreter.arm-air.a(idct_part. o)
    ld: warning: ARM function not 4-byte aligned: IDCT1_plus_ReconBlock_loop from /Applications/Adobe Flash Builder 4.6/sdks/4.6.0/lib/aot/lib/libRuntimeInterpreter.arm-air.a(idct_part. o)
    ld: warning: ARM function not 4-byte aligned: _IDCT1_plus_ReconInter_ARM from /Applications/Adobe Flash Builder 4.6/sdks/4.6.0/lib/aot/lib/libRuntimeInterpreter.arm-air.a(idct_part. o)
    ld: warning: ARM function not 4-byte aligned: IDCT1_plus_ReconInter_loop from /Applications/Adobe Flash Builder 4.6/sdks/4.6.0/lib/aot/lib/libRuntimeInterpreter.arm-air.a(idct_part. o)
    ld: warning: ARM function not 4-byte aligned: _FilterBlock1dH_ARM11 from /Applications/Adobe Flash Builder 4.6/sdks/4.6.0/lib/aot/lib/libRuntimeInterpreter.arm-air.a(predfilter s.o)
    ld: warning: ARM function not 4-byte aligned: loop1 from /Applications/Adobe Flash Builder 4.6/sdks/4.6.0/lib/aot/lib/libRuntimeInterpreter.arm-air.a(predfilter s.o)
    ld: warning: ARM function not 4-byte aligned: _FilterBlock1dV_ARM11 from /Applications/Adobe Flash Builder 4.6/sdks/4.6.0/lib/aot/lib/libRuntimeInterpreter.arm-air.a(predfilter s.o)
    ld: warning: ARM function not 4-byte aligned: loop3 from /Applications/Adobe Flash Builder 4.6/sdks/4.6.0/lib/aot/lib/libRuntimeInterpreter.arm-air.a(predfilter s.o)
    ld: warning: ARM function not 4-byte aligned: loop4 from /Applications/Adobe Flash Builder 4.6/sdks/4.6.0/lib/aot/lib/libRuntimeInterpreter.arm-air.a(predfilter s.o)
    ld: warning: ARM function not 4-byte aligned: _FilterBlock2dFirstPass_ARM11 from /Applications/Adobe Flash Builder 4.6/sdks/4.6.0/lib/aot/lib/libRuntimeInterpreter.arm-air.a(predfilter s.o)
    ld: warning: ARM function not 4-byte aligned: loop5 from /Applications/Adobe Flash Builder 4.6/sdks/4.6.0/lib/aot/lib/libRuntimeInterpreter.arm-air.a(predfilter s.o)
    ld: warning: ARM function not 4-byte aligned: _FilterBlock1dBilH_ARM11 from /Applications/Adobe Flash Builder 4.6/sdks/4.6.0/lib/aot/lib/libRuntimeInterpreter.arm-air.a(predfilter s.o)
    ld: warning: ARM function not 4-byte aligned: FilterBlock1dBilH_next_row from /Applications/Adobe Flash Builder 4.6/sdks/4.6.0/lib/aot/lib/libRuntimeInterpreter.arm-air.a(predfilter s.o)
    ld: warning: ARM function not 4-byte aligned: _FilterBlock1dBilV_ARM11 from /Applications/Adobe Flash Builder 4.6/sdks/4.6.0/lib/aot/lib/libRuntimeInterpreter.arm-air.a(predfilter s.o)
    ld: warning: ARM function not 4-byte aligned: FilterBlock1dBilV_outer_loop from /Applications/Adobe Flash Builder 4.6/sdks/4.6.0/lib/aot/lib/libRuntimeInterpreter.arm-air.a(predfilter s.o)
    ld: warning: ARM function not 4-byte aligned: FilterBlock1dBilV_inner_loop from /Applications/Adobe Flash Builder 4.6/sdks/4.6.0/lib/aot/lib/libRuntimeInterpreter.arm-air.a(predfilter s.o)
    ld: warning: ARM function not 4-byte aligned: _FilterBlock2dBil_FirstPass_ARM11 from /Applications/Adobe Flash Builder 4.6/sdks/4.6.0/lib/aot/lib/libRuntimeInterpreter.arm-air.a(predfilter s.o)
    ld: warning: ARM function not 4-byte aligned: FilterBlock2dBil_FirstPass_next_row from /Applications/Adobe Flash Builder 4.6/sdks/4.6.0/lib/aot/lib/libRuntimeInterpreter.arm-air.a(predfilter s.o)
    ld: warning: ARM function not 4-byte aligned: _ReconIntra_ARM11 from /Applications/Adobe Flash Builder 4.6/sdks/4.6.0/lib/aot/lib/libRuntimeInterpreter.arm-air.a(reconstruc t-F6251070C86EBC8D.o)
    ld: warning: ARM function not 4-byte aligned: loop from /Applications/Adobe Flash Builder 4.6/sdks/4.6.0/lib/aot/lib/libRuntimeInterpreter.arm-air.a(reconstruc t-F6251070C86EBC8D.o)
    ld: warning: ARM function not 4-byte aligned: _ReconInter_ARM11 from /Applications/Adobe Flash Builder 4.6/sdks/4.6.0/lib/aot/lib/libRuntimeInterpreter.arm-air.a(reconstruc t-F6251070C86EBC8D.o)
    ld: warning: ARM function not 4-byte aligned: loop1 from /Applications/Adobe Flash Builder 4.6/sdks/4.6.0/lib/aot/lib/libRuntimeInterpreter.arm-air.a(reconstruc t-F6251070C86EBC8D.o)
    ld: warning: ARM function not 4-byte aligned: _ReconBlock_ARM11 from /Applications/Adobe Flash Builder 4.6/sdks/4.6.0/lib/aot/lib/libRuntimeInterpreter.arm-air.a(reconstruc t-F6251070C86EBC8D.o)
    ld: warning: ARM function not 4-byte aligned: ReconBlock_ARM11_LOOP from /Applications/Adobe Flash Builder 4.6/sdks/4.6.0/lib/aot/lib/libRuntimeInterpreter.arm-air.a(reconstruc t-F6251070C86EBC8D.o)
    ld: warning: ARM function not 4-byte aligned: _Copy12x12_ARM9E from /Applications/Adobe Flash Builder 4.6/sdks/4.6.0/lib/aot/lib/libRuntimeInterpreter.arm-air.a(copy12x12. o)
    ld: warning: ARM function not 4-byte aligned: Copy12x12_CSrcAlign0 from /Applications/Adobe Flash Builder 4.6/sdks/4.6.0/lib/aot/lib/libRuntimeInterpreter.arm-air.a(copy12x12. o)
    ld: warning: ARM function not 4-byte aligned: Copy12x12_CSrcAlign1 from /Applications/Adobe Flash Builder 4.6/sdks/4.6.0/lib/aot/lib/libRuntimeInterpreter.arm-air.a(copy12x12. o)
    ld: warning: ARM function not 4-byte aligned: Copy12x12_CSrcAlign2 from /Applications/Adobe Flash Builder 4.6/sdks/4.6.0/lib/aot/lib/libRuntimeInterpreter.arm-air.a(copy12x12. o)
    ld: warning: ARM function not 4-byte aligned: Copy12x12_CSrcAlign3 from /Applications/Adobe Flash Builder 4.6/sdks/4.6.0/lib/aot/lib/libRuntimeInterpreter.arm-air.a(copy12x12. o)
    ld: warning: ARM function not 4-byte aligned: _tDecodeBool from /Applications/Adobe Flash Builder 4.6/sdks/4.6.0/lib/aot/lib/libRuntimeInterpreter.arm-air.a(tDecodeBoo l.o)
    ld: warning: ARM function not 4-byte aligned: _tDecodeBool128 from /Applications/Adobe Flash Builder 4.6/sdks/4.6.0/lib/aot/lib/libRuntimeInterpreter.arm-air.a(tDecodeBoo l.o)
    Jul 20, 2012 2:15 AM   in reply to aSuitableBoy
    These warnings are expected, and shouldn't be creating problems for you.
    You mentioned that the iOS 5 specific things are not working when you do not use platformsdk option, which is also expected as AIR 3.1 only has support for iOS 4.x. You may use AIR 3.3, which has built-in support for iOS5 SDK, then, you won't have to specify -platformsdk switch.
    What are the strange errors you are talking about?
    Jul 20, 2012 2:23 AM   in reply to neh@adobe
    Hi, thanks for the update, though do you think SDK 3.3 even help, as "Devarai" mentioned that s/he has trouble building with ADT which also warned of '-ios_version_min not specificed, assuming 4.0' and other lot of warnings (?) I've also seen some other people also has trouble with 3.3 and these warnings.
    By other error I meant, as I mentioned, I have a StageVideo invovlement in my application also. When I install IPA with these warnings build, the StageVideo starts, and at the time of terminate the video by 'stream.close()' and 'stream.dispose()', the application terminates. I specifically saying about these 2 commands, because I've seen if I comment them from my code, the application is running though the stream is not closing apparently.
    Jul 20, 2012 5:43 AM   in reply to aSuitableBoy
    Just as an add-on, as suggested, I've updated the projects with SDK 3.3, re-compiled. The build as well warned with list of warnings when Terminal, but anyway after the IPA packaged, I've tested, and fortunately the evermentioned error has gone (StageVideo crash), and it seems the iOS 5.0 feature is also working. Thanks. Though its still irritating why those warnings are coming.
