Table rows in print document
Jul 17, 2012 8:43 AM
RoboHelp 9.0.2.271
Word 2010
Windows 7
PC
Still working with equations: a "where" table follows the equation and explains the terms and variables in the equation. I want the vertical spacing in the print document to look as close to the WebHelp as possibl--and it's not.
Everything looks good in the WebHelp.
However, in the print document there is far too much vertical space between the table rows.
I checked my RH stylesheet and the three styles used in a row (right-, center- and left-aligned) are the same except for the horizontal alignment. I checked the Word styles and they appear to be okay. I also tried manually adjusting the row height in the print document, but even though I get the pointer showing I can adjust the row height, nothing happens.
In addition, sometimes a table contains rows of variable heights--some are what I want and some have the extra vertical space.
If all rows were the same height, I would accept that this is just the way RoboHelp works. However since some rows are the way they should be, I'm just wondering what is going on.
Thanks in advance for any insight.
- Mary
    Jul 20, 2012 6:07 AM   in reply to Crone2011
    You are referring to generating a printed document rather than the user printing the topic, correct?
    If you are using the project CSS in the last page of the wizard, try mapping to a Word template, you have more control by mapping the RoboHelp styles to Word styles and you can edit the Word styles. Not sure if that is the issue but it's worth trying. There is more about printed documentation on my site.
    @petergrainge
