Using Captivate 6. Can I edit the mouse movement for video capture? I see a can change the mouse pointer and smooth the movement.
My problem is that when I trim the video, the speed of the mouse pointer slows to a crawl in some parts of the video. Can I move or adjust the mouse timing or speed.
Does anyone have a suggestion as to a better workflow?
Thanks in advance, Marc
Hello,
Please share your contact details on tcssup@adobe.com
I will try to contact you.
Vikram
Vikram,
I think that Kurrykid is talking about the new Video capture in Captivate 6. And AFAIK there is no way to change the mouse speed for a captured mouse movement, would like to know also if that is possible. Mostly when the mouse is crawling too slow, I will hide the mouse and just show the Mouse click at the end with a proper setting.
Lilybiri
Thanks everyone for your responses.
After experimenting a bit, I found you can control (kind of) the mouse speed by adding or removing a mouse object from the timeline. So in my case where the pointer was going to slow, I added a mouse pointer a few seconds before the pointer I needed to speed up. (Lilybiri perhaps you can experiment and confirm).
Note: this tip applies to Video Demo mode in Captivate 6.
Thanks, Marc
