Edit Mouse for Video
Jul 19, 2012 5:50 PM
Tags: #video #capture #mouse_movement
Using Captivate 6. Can I edit the mouse movement for video capture? I see a can change the mouse pointer and smooth the movement.
My problem is that when I trim the video, the speed of the mouse pointer slows to a crawl in some parts of the video. Can I move or adjust the mouse timing or speed.
Does anyone have a suggestion as to a better workflow?
Thanks in advance, Marc
    Jul 20, 2012 6:10 AM   in reply to mvk66
    Hello,
    Welcome to Adobe Forums.
    When you select the mouse pointer, under properties inspector (Right Hand side), you can change the timing of mouse pointer (To adjust the time and speed)
    Hope this helps !!
    Vikram
    Jul 20, 2012 7:00 AM   in reply to VikramGaur
    I don't see any properties for the mouse timing in the Property Inspector???
    Jul 20, 2012 7:03 AM   in reply to Kurrykid
    Hello,
    Please share your contact details on tcssup@adobe.com
    I will try to contact you.
    Vikram
    Jul 20, 2012 7:37 AM   in reply to VikramGaur
    Vikram,
    I think that Kurrykid is talking about the new Video capture in Captivate 6. And AFAIK there  is no way to change the mouse speed for a captured mouse movement, would like to know also if that is possible. Mostly when the mouse is crawling too slow, I will hide the mouse and just show the Mouse click at the end with a proper setting.
    Lilybiri
    Jul 20, 2012 7:52 AM   in reply to Kurrykid
    KurryKid,
    If you have done a Video Demo in Captivate 6 , then you can't change the Speed and timing for a mouse movement.
    In Software Simulation you can change Speed and timing for a mouse movement, as it comes as an object in timeline.
    Vikram
    Jul 20, 2012 8:21 AM   in reply to VikramGaur
    OK, thanks. I wasn't the one that started the thread, I just became curious about the answer.
    Thanks again for the clarification.
