when drawing a custom shape with the pen tool, let's say i am trying to draw the top-half of a circle (except the top-half line is flat). i get as far as the bottom right corner, and then when i try to line up the upper-right corner with the upper-left corner by eye, i create the rounded side, but then when i go to connect to the upper-left corner, it is not directly across so it curves it. do i need to use guides, or what is the best way to ensure that i am directly across from a point?
i am trying to do this tutorial, and am working on the black lines on the bee. http://www.webdesign.org/photoshop/drawing-techniques/drawing-a-bee.13 386.html
For the black lines, I'd draw simple rectangles or lines with varied strokes, then make a copy of the yellow oval (the bee's lower body), place it above those vectors, and apply it as a mask (using Modify > Mask > Group As Mask). This would make it easier to create the rounded edges and match them to the existing shape.
But that's unrelated to your original question. My general advice is, if a tutorial leaves you with too many questions, move on to another one that's more educational.
(Incidentally, instead of masking, you might use one of the Combine Paths commands to create similar visual results—using the oval shape as a cookie-cutter for the black lines.)
