Thanks for anyone's help. I'm a first time user of the forum so please excuse any protocol errors.
I can't get my drop-down menu to display on my web page (http://www.cglcontracting.com/) on a Windows platform using Dreamweaver CS5.5.
Thanks very much for any advice/help.
Unrelated, but this link is pointing to your local computer:
<script src="file:///C|/Users/Arne/Documents/Programming/CGL/upload files/Scripts/swfobject_modified.js" type="text/javascript"></script>
Hi -
Sorry, not an expert, but I think the cascade is getting stopped somewhere.
Just for giggles, remove the empty lines between the z-indexand the filter, save and upload and let's see if that's the problem
/* HACK FOR IE: to make sure the sub menus show above form controls, we underlay each submenu with an iframe */
ul.MenuBarHorizontal iframe
z-index: 1010;
filter:alpha(opacity:0.1);
position: relative;
Hi again -
My previous suggestion did not seem to make any difference, the CSS still did not validate.
I seems to be choking on your Browser Hack section.
I re-wrote the bottom Browser Hack section and it now validates.
I'll paste the whole CSS file here, Save it as "SpryMenuBarHorizontal.css" and give it a try.
@charset "UTF-8";
/* SpryMenuBarHorizontal.css - version 0.6 - Spry Pre-Release 1.6.1 */
/* Copyright (c) 2006. Adobe Systems Incorporated. All rights reserved. */
LAYOUT INFORMATION: describes box model, positioning, z-order
/* The outermost container of the Menu Bar, an auto width box with no margin or padding */
margin: 0;
padding: 0;
list-style-type: none;
font-size: 90%;
cursor: default;
width: auto;
color: rgb(153,153,153);
text-transform: uppercase;
font-family: "Trebuchet MS", Arial, Helvetica, sans-serif;
text-align: center;
background-color: rgb(255,255,255);
vertical-align: middle;
/* Set the active Menu Bar with this class, currently setting z-index to accomodate IE rendering bug: http://therealcrisp.xs4all.nl/meuk/IE-zindexbug.html */
ul.MenuBarActive
z-index: 1000;
/* Menu item containers, position children relative to this container and are a fixed width */
ul.MenuBarHorizontal li
margin: 0;
padding: 0;
font-size: 100%;
position: relative;
text-align: left;
cursor: pointer;
width: 8em;
float: left;
color: rgb(0,255,0);
overflow: hidden;
visibility: inherit;
/* Submenus should appear below their parent (top: 0) with a higher z-index, but they are initially off the left side of the screen (-1000em) */
ul.MenuBarHorizontal ul
padding: 0;
font-size: 100%;
z-index: 1020;
cursor: default;
width: 8.2em;
color: rgb(204,204,204);
top: 0px;
overflow: auto;
margin-top: -5%;
margin-left: 95%;
/* Submenu that is showing with class designation MenuBarSubmenuVisible, we set left to auto so it comes onto the screen below its parent menu item */
ul.MenuBarHorizontal ul.MenuBarSubmenuVisible
font-variant: small-caps;
background-color: rgb(255,0,0);
left: auto;
width: auto;
z-index: auto;
/* Menu item containers are same fixed width as parent */
ul.MenuBarHorizontal ul li
text-align: left;
/* Submenus should appear slightly overlapping to the right (95%) and up (-5%) */
ul.MenuBarHorizontal ul ul
background-color: rgb(204,204,204);
margin-top: -5%;
margin-right: 0;
margin-bottom: 0;
margin-left: 95%;
/* Submenu that is showing with class designation MenuBarSubmenuVisible, we set left to 0 so it comes onto the screen */
ul.MenuBarHorizontal ul.MenuBarSubmenuVisible ul.MenuBarSubmenuVisible
left: 100px;
DESIGN INFORMATION: describes color scheme, borders, fonts
/* Submenu containers have borders on all sides */
border: 0px none #CCC;
margin-top: 0%;
margin-right: 0%;
margin-bottom: 0%;
margin-left: 0%;
/* Menu items are a light gray block with padding and no text decoration */
ul.MenuBarHorizontal a
display: block;
cursor: pointer;
background-color: #F00;
color: #003;
text-decoration: none;
text-align: center;
font-family: Arial, Helvetica, sans-serif;
padding-top: 1.2ex;
font-weight: bold;
padding-bottom: 0.53em;
/* Menu items that have mouse over or focus have a blue background and white text */
ul.MenuBarHorizontal a:hover, ul.MenuBarHorizontal a:focus
background-color: #000;
text-align: center;
/* Menu items that are open with submenus are set to MenuBarItemHover with a blue background and white text */
ul.MenuBarHorizontal a.MenuBarItemHover, ul.MenuBarHorizontal a.MenuBarItemSubmenuHover, ul.MenuBarHorizontal a.MenuBarSubmenuVisible
background-color: #900;
color: #066;
text-align: center;
SUBMENU INDICATION: styles if there is a submenu under a given menu item
/* Menu items that have a submenu have the class designation MenuBarItemSubmenu and are set to use a background image positioned on the far left (95%) and centered vertically (50%) */
background-image: url(SpryMenuBarDown.gif);
background-repeat: no-repeat;
background-position: 98% 50%;
color: rgb(0,0,51);
ul.MenuBarHorizontal ul a.MenuBarItemSubmenu
background-image: url(SpryMenuBarRight.gif);
/* Menu items that are open with submenus have the class designation MenuBarItemSubmenuHover and are set to use a "hover" background image positioned on the far left (95%) and centered vertically (50%) */
background-image: url(SpryMenuBarDownHover.gif);
background-color: rgb(153,0,0);
visibility: visible;
ul.MenuBarHorizontal ul a.MenuBarItemSubmenuHover
background-image: url(SpryMenuBarRightHover.gif);
background-color: rgb(153,153,153);
BROWSER HACKS: the hacks below should not be changed unless you are an expert
ul.MenuBarVertical iframe
position: absolute;
z-index: 1010;
/* HACK FOR IE: to stabilize appearance of menu items; the slash in float is to keep IE 5.0 from parsing */
@media screen, projection
ul.MenuBarVertical li.MenuBarItemIE
display: inline;
f\loat: left;
background: #FFF;
Hi -
Well, for a newbie, you certainly put a great design together.
Good news, you don't need to change anything in your pages;
We're just swapping a current file with a revised version.
If you look in your source code, you will see this tag in the head section :
<link href="SpryAssets/SpryMenuBarHorizontal.css" rel="stylesheet" type="text/css">
This tells you that your page menu needs to use a separate CSS file named SpryMenuBarHorizontal.css
which can be found in a folder named SpryAssets. This file controls the styling of your menu.
This is the file I revised and posted above. While it is a text file, it must be named SpryMenuBarHorizontal.css as I posted, with careful attention to matching the capitalization exactly.
First, go to the SpryAssets folder (in your local site root folder) and find the current SpryMenuBarHorizontal.css file
and rename it to OLDSpryMenuBarHorizontal.css (in case you wish to go back to the original)
Second, copy or move the file I sent you into the SpryAssets folder.
Third, upload the revised SpryMenuBarHorizontal.css file to the SpryAssets folder on your remote site.
Then let's see if your menu works. If you wish to talk about it and you are in the US, you may call me at 914-941-3616
Good luck
Your SpryMenuBarHorizontal.css file has been mangled to death. It is no longer of any use.
The best way is to resurrect the original SpryMenuBarHorizontal.css and make the following additions to the very bottom of the file.
ul.MenuBarHorizontal {
font-size: 90%;
ul.MenuBarHorizontal li {
width: auto;
ul.MenuBarHorizontal ul {
width: auto;
ul.MenuBarHorizontal ul li {
display: block;
float: none !important;
width: auto;
white-space: nowrap;
border-bottom: solid 1px #EEE;
ul.MenuBarHorizontal a {
background-color: #ff0000;
color: #003;
padding: 0.5em 1.75em;
ul.MenuBarHorizontal a.MenuBarItemSubmenu {
padding: 0.5em 2em 0.5em 1.75em;
ul.MenuBarHorizontal a:hover, ul.MenuBarHorizontal a:focus {
color: #066;
ul.MenuBarHorizontal a.MenuBarItemHover, ul.MenuBarHorizontal a.MenuBarItemSubmenuHover, ul.MenuBarHorizontal a.MenuBarSubmenuVisible {
color: #066;
The best way to get a new copy of the original CSS is to
Once you have done that, open SpryMenuBarHorizontal.css and copy and paste the above mentioned style rules at the very bottom of the file. This will ensure that the defaults will be overridden.
There is still a couple of little nasties to get rid of.
a:hover {
border-top-style: none;
border-right-style: none;
border-bottom-style: none;
border-left-style: none;
height: 33px;
a:active {
background-color: rgb(255,51,0);
border-top-width: thick;
border-bottom-width: thick;
border-top-style: solid;
border-bottom-style: solid;
border-top-color: rgb(255,0,0);
border-bottom-color: rgb(255,0,0);
Follow the above and you are done.
It may be worthwhile having a look at http://www.dwcourse.com/dreamweaver/ten-commandments-spry-menubars.php
Gramps
Thanks again Gramps. I got it sorted out (for all the browsers) but I am wondering if there is any way to match the size of the highlight colour to that of the original menu size as well as the width of the drop-down menu. Also, can the white border of the drop-down menu be removed? I did try (for some time) to go through Dreamweaver's 'properties' menu to change these, but I can't find them (and don't want to mess up what you've already helped me fix!).
You have got a stray style rule on line #202 of SpryMenuBarHorizontal (padding-bottom: 1em;). Under no condition should that be there. If you want to increase the height of the menu bar, please let me know and I will come up with a fix.
Sorry, could you elaborate on this, I am not sure what it is that you want changed.
Remove line #86 (border: 1px solid #CCC;) of SpryMenuBarHorizontal.css
Gramps
Hi again Gramps,
Thanks for the line #202 correction. I actually looked at that last night and wondered about it...but my lack of knowledge/ability is obviously glaringly obvious as I don't know what impact it has.
Sorry for the vagueness of my request. When the mouse goes over the primary menu items the highlight colour is a few pixels 'shorter' than the original menu item so there is a thin bar of the original primary menu item showing.
Also, the drop-down menu is wider than the primary menu item under which it is displayed. Is there any way to match the width of the submenu to it's 'parent' as well as align the top of the drop-down menu to the bottom of the primary item above it?
And finally, the drop-down menu items each have a white (single pixel) border around each of them. Can that be removed?
I sure appreciate your help AND patience. I'm learning, but slowly!
Thanks again,
Dixey-Rose
I think the following addresses can simplify our work:
http://cssmenumaker.com/dreamweaver-css-menu-extension
have a lot of ease in the offer and just copy and paste it
